Diebold-Yilmaz EJ 2009
dieboldyilmaz_ej2009.zip is a set of replication files for Diebold and Yilmaz(2009), "Measuring Financial Asset Return and Volatility Spillovers, with Application to Global Equity Markets," Economic Journal, vol. 119, no. 534, 158-171. This does both the full sample and rolling VAR analyses.
Detailed description
dec3fc
Re: Diebold-Yilmaz EJ 2009
Thank you very much for making this replication files available. I have managed to compute and graph both standard (Diebold and Yilmaz, 2009) and generalised (Diebold and Yilmaz, 2011) spillover indices. However, I am having a difficulty in getting the values and figures for both gross and net directional To/From indices appearring in Diebold and Yilmaz (2011). I would be most grateful if you could please advise on what need to be added or changed in this replication file in order to compute the directional measures and figures.
Many thanks
Frankie
Many thanks
Frankie
I'm a bit confused about the question. The same measures are being used in both the 2009 and 2011 papers, and are included in the borders of the table. The one major difference with the 2011 paper is that the values are invariant to order.
dec3fc
Many thanks for the prompt response. In 2011 paper, in addition to putting forward a measure which is invariant to the order of variables, the authors have also decomposed the total contribution into a few directional measures to capture the contribution 'to and from' a particular market i (as in figures 3 -6). My initial question was how could we compute these directional measures and figures using the replicated files you have kindly provided us.
Many thanks
Frankie
Many thanks
Frankie
No. That's still the same information. In the N x N table, the "To"'s are in the columns and the "From"s are in the rows.dec3fc wrote:Hi Tom,
Many thanks
Frankie
timkrause
I just started looking at this since I am also interested in using the 2011 program. I believe Frankie is referring to Figure 6 in DY2011 where they create and chart the time series of net pairwise volatility spillovers. I will try to modify the code to extract these variables. Any other suggestions would be appreciated.
Tim
Tim
The directional values are obtained using
ewise fromvar(i)=%sum(%xrow(gfevdx,i))-gfevdx(i,i)
ewise tovar(i)=%sum(%xcol(gfevdx,i))-gfevdx(i,i)
where gfevdx is the extracted value for a particular horizon. 100.0*fromvar(i) is the contribution from other variables to variable i(in percentages). 100.0*tovar(i) is the total contribution to all other variables from variables to i. The bilateral i to j is 100.0*gfevdx(j,i)/%sum(%xrow(gfevdx,j)). Whichever calculations you need for the rolling calculations have to be saved into a slot in a series so they can be graphed later.
timkrause
Thanks Tom,
Yes, I figured out that the needed values were in "gfevdx", so I'm trying to add code to pull them out of that matrix and into series' during each iteration.
Tim
Tim
timkrause
Got it. I have a 10 x 10 matrix and I was interested in the spill from column one to row two. So I inserted this statement in the rolling window analysis, just below compute spillvols(end)...
compute tovol2(end)=100.0*gfevdx(2,1)
I also needed to initialize the series with "set tovol1 rstart+nspan-1 rend = 0.0" just below "set spillvols rstart..."
Hope that helps,
Tim
Hope that helps,
Tim
tomcy
Hi Tim and Tom,
Thanks for the information above, it is really useful. Similar to other posts above, I am trying to replicate the directional spillover charts plotted in Figure 3 to Figure 6 of the Diebold and Yilmaz (2011) paper. To start, I am looking at the directional spillovers to others and from others (figs 3 and 4). I understand how the values I need come from gfevdx but I have been struggling a bit with saving and graphing the series from the rolling regression. I think I have almost figured out the code and wanted to check here that I am doing this correctly. To obtain the spillovers from variable (1) to all other variables (from stocks to others as in top left panel of Figure 3 in DY 2011 paper), I have added the following two lines to the original code (as well as set vol1 rstart+….to initialise the series):
compute vol1(end)=100.0*fromvar(1)
My code looks like this (my additions to original code in red):
compute spillreturns(end)=100.0*%sum(tovar)/%nvar
end do end
graph(footer="Spillover plot. Returns. 200 week window. 10 step horizon")
# vol1
Similarly to obtain the directional spillovers to variable (1) from others (Fig 4) I use:
compute vol2(end)=100.0*tovar(1)
To obtain the spillovers to variables (2),(3),(4), I use compute vol2(end)=100.0*tovar(2) etc and so on for variables (3) and (4). Is this the appropriate way to calculate the directional spillovers to and from the four variables? Any advice would be greatly appreciated.
Thank you,
Tom
end do end
# vol1
Thank you,
Tom
blucey
Im also wondering about the individual directional spillovers a la 2011 paper. Anybody get any further with this?
nikosant82
Does it make sense to use Structural decomposition, instead of Cholesky (or GIRF), and do the spillover index analysis as in Diebold and Yilmaz (2009)?
I have amended the code by estimating an SVAR model and everything seems to work fine up to the generation of the Spillover table.
However, when I try to generate the spillover plot using rolling windows I get the following mistake:
Something is wrong with the data range and which I cannot understand.
I would be very grateful if you could help me finding the solution to this and whether the structural decomposition and code I've prepared make sense?
Many thanks,
Nikos
## SR5. Writing Range -32707 to 198 of Series SPILLRETURNS. (Incorrect start,end or SMPL)I would be very grateful if you could help me finding the solution to this and whether the structural decomposition and code I've prepared make sense?
Many thanks,
Nikos
You could, thought it's not particularly interesting, since you're just reading information out of a standard FEVD.nikosant82 wrote:Dear Tom,
You have to movenikosant82 wrote: I have amended the code by estimating an SVAR model and everything seems to work fine up to the generation of the Spillover table.
Something is wrong with the data range and which I cannot understand.Code: Select all
compute rstart=%regstart(),rend=%regend()
up after the ESTIMATE instruction. Because you have an extra estimation instruction that wasn't in the original program (CVMODEL) the %REGSTART() and %REGEND() get redefined from what they were immediately after the ESTIMATE.
zy761
Dear Tom,TomDoan wrote:The directional values are obtained using
In addition to the bilateral volatility spillover index from variable i to variable j, is it able to to calculate the index from a group of variable (e.g. a,b,c) to another group of variable (e.g. x,y,z) (The number of variables in the group is less than the total variables in the system)?
Best regards,
Jasmine
