cointegrating nonlinear ARDL
Hi All,
I am looking for RATS code to estimate a cointegrating nonlinear ARDL as in the paper by Shin, Y., Yu, B. and Greenwood-Nimmo, M.J. (2012, April). "Modelling Asymmetric Cointegration and Dynamic Multipliers in a Nonlinear ARDL Framework" which can be found at this link: http://www.greenwoodeconomics.com/workingpapers.html.
There is a gauss code in the link.
Thanks in advance for your help.
Oz
Oz
Re: cointegrating nonlinear ARDL
There's nothing particularly difficult about that - it's LINREG's with a search over the threshold value. However, if there is any Gauss code on that link, I don't see it.
I have now managed to run the Gauss version of the code.
But I guess a RATS code will still be useful for RATS users.
Oz
Oz
TVolscho-286
Could some of the Enders-Siklos code be modified to pick thresholds from an ARDL? Has anyone tried this?
This is the set of codes developed for eviews. Might be helpful to develop one for RATS?TVolscho-286 wrote:Could some of the Enders-Siklos code be modified to pick thresholds from an ARDL? Has anyone tried this?
This provides guidance on how to run the code
Put all the files in one folder and data in excel file just like the one provided with codes. Then set the Step=1 and make the changes as per your data and run. It will make the work file from excel according to the settings provided below. Then set STEP=2 to run NARDL and to get multipliers.
!step=1 ‘set STEP=1 and Run after the work file is in E view then set STEP=2 to run the estimations
!multiplierlength = 16 The time period for which multiplier effect is required'Specifies the period in which the unit shock occurs. The shock occurs in the last period minus multiplier length
!bandwidth = 1.64 Do not change 'Sets the bandwidth for standard errors
!laglength = 1 ‘The number of lags to include as search parameters in the G2S regression
!tb=0 Do not change '0=without brk and trend** 1=trend** 2=brk** 3=brk & trend
!sig=0.05 ' level of significance for G2S
'************************ SETTINGS *************************
!s=3 '*** The scenario of NARDL; 1) IV=1 & nonlinear ************* 2). IVs=2, 1st=linear, 2nd=nonlinear ************* 3). IVs=2 & both non-linear ************* 4). IVs=3, 1st & 2nd=linear, 3rd=Non-linear ******5). IVs=3 all non-linear
'***Workfile
%datafile = "ARDLdata.xls" 'For the data file in the root directory
%dependent = "lfp" 'Ensure the names match exactly with those imported from the excel file
%independent1 = "ly" 'As above
%independent2 = "lwti"
%independent3 = "--"
%firstperiod = "1971" 'The first period of estimation
%lastperiod = "2012" 'The last period of estimation
'************************ WORKFILE *************************
if !step=1 then
'***Create workfile and set sample
wfcreate(wf = workfile, page = yearly) y {%firstperiod} {%lastperiod} 'Can be set for daily, weekly, monthly, yearly
Ozmando wrote:TVolscho-286 wrote:Could some of the Enders-Siklos code be modified to pick thresholds from an ARDL? Has anyone tried this?
***Quiet mode
mode quiet
'***Multiplier
!step=1 ' To apprpriately run the NARDL first set STEP=1 and select the lag lenth after lag length selection set STEP=2 to run the estimations
!multiplierlength = 16 'Specifies the period in which the unit shock occurs. The shock occurs in the last period minus multiplier length
!bandwidth = 1.64 'Sets the bandwidth for standard errors
!laglength = 1 'The number of lags to include as search parameters in the G2S regression
!tb=0 '0=without brk and trend** 1=trend** 2=brk** 3=brk & trend
'***Workfile
if !step=1 then
import .\{%datafile} 'Imports datafile
'Gerenerate trend and break'
series tr=@trend()
'{%dependent}.buroot(dif=0,nograph,output=buoutput)
'!idate = buoutput(@imin(buoutput.@col(7)),1)
'string date = @otod(!idate+1)
'freeze(brk1) {%dependent}.buroot(dif=0, nograph)
'{%date}=brk1(6,1)
'series brk = @recode(@date>@dateval("{date}"), 1, 0)
'smpl %firstperiod {date}
'series brk=0
'smpl {date} %lastperiod
'brk=1
'smpl %firstperiod %lastperiod
'delete buoutput date
'Generate positive(negative) cummulative sums
if !s=1 then
GENR X={%independent1}
GENR DX=X-X(-1)
GENR POS=DX>=0
GENR DXPOS=POS*DX
GENR DXNEG=(1-POS)*DX
GENR XPOS=@CUMSUM(DXPOS)
GENR XNEG=@CUMSUM(DXNEG)
GENR {%independent1}_P=XPOS
GENR {%independent1}_N=XNEG
DELETE X DX POS DXPOS DXNEG XPOS XNEG
GENR D{%independent1}=D({%independent1})
GENR D{%independent1}_P=D({%independent1}_P)
GENR D{%independent1}_N=D({%independent1}_N)
else if !s=2 then
GENR X={%independent2}
GENR DX=X-X(-1)
GENR POS=DX>=0
GENR DXPOS=POS*DX
GENR {%independent2}_P=XPOS
GENR {%independent2}_N=XNEG
GENR D{%independent2}=D({%independent2})
GENR D{%independent2}_P=D({%independent2}_P)
GENR D{%independent2}_N=D({%independent2}_N)
else if !s=3 then
GENR DX=X-X(-1)
GENR POS=DX>=0
GENR DXPOS=POS*DX
GENR DX=X-X(-1)
GENR POS=DX>=0
GENR DXPOS=POS*DX
else if !s=4 then
GENR X={%independent3}
GENR DX=X-X(-1)
GENR POS=DX>=0
GENR DXPOS=POS*DX
GENR {%independent3}_P=XPOS
GENR {%independent3}_N=XNEG
GENR D{%independent3}=D({%independent3})
GENR D{%independent3}_P=D({%independent3}_P)
GENR D{%independent3}_N=D({%independent3}_N)
else if !s=5 then
GENR DX=X-X(-1)
GENR POS=DX>=0
GENR DXPOS=POS*DX
GENR DX=X-X(-1)
GENR POS=DX>=0
GENR DXPOS=POS*DX
GENR DX=X-X(-1)
GENR POS=DX>=0
GENR DXPOS=POS*DX
endif
endif
endif
endif
endif
'Generate first difference series
GENR D{%dependent}=D({%dependent})
else if !step=2 then
'***Include sub-procedures
if !tb=0 then
include .\02_nardl
else if !tb=1 then
include .\02_nardl1
else if !tb=2 then
include .\02_nardl2
else if !tb=3 then
include .\02_nardl3
endif
endif
endif
endif
include .\03_mplier
'***Save workfile
'wfsave(2) .\workfile.wf1
delete coefs_{%dependent} cov_{%dependent}
endif
endif
Ozmando wrote:Ozmando wrote:TVolscho-286 wrote:Could some of the Enders-Siklos code be modified to pick thresholds from an ARDL? Has anyone tried this?
'******************** NARDL ESTIMATION *********************
'***Set sample period
'***Define loop
if !s=1 then
for %i {%dependent}
'****model
equation nardl_{%i}.stepls(method = uni, back, btol = !sig) d({%i}) c {%i}(-1) {%independent1}_p(-1) {%independent1}_n(-1) @ d{%i}(-1 to -{!laglength}) d{%independent1}_p(-0 to -{!laglength}) d{%independent1}_n(-0 to -{!laglength})
coef coefs_{%i} = c
'***Store results and conduct tests
sym cov_{%i} = nardl_{%i}.@coefcov
scalar BDM_{%i} = c(2)/@stderrs(2)
freeze(SerCorr_{%i}) nardl_{%i}.auto(12)
freeze(HSked_{%i}) nardl_{%i}.hettest(type = White, c)
freeze(Cusum_{%i}) nardl_{%i}.rls(v)
'store coeffecients
freeze(LRW_{%independent1}) nardl_{%i}.wald -c(3)/c(2) = -c(4)/c(2)
freeze(LR_{%independent1}_P) nardl_{%i}.wald -c(3)/c(2) = 0
freeze(LRW_{%independent1}_N) nardl_{%i}.wald -c(4)/c(2) = 0
freeze(PSS_{%i}) nardl_{%i}.wald c(2) = c(3) = c(4) = 0
next
else if !s=2 then
for %i {%dependent}
'****Model
equation nardl_{%i}.stepls(method = uni, back, btol = !sig) d({%i}) c {%i}(-1) {%independent1}(-1) {%independent2}_p(-1) {%independent2}_n(-1) @ d{%i}(-1 to -{!laglength}) d{%independent1}(-0 to -{!laglength}) d{%independent2}_p(-0 to -{!laglength}) d{%independent2}_n(-0 to -{!laglength})
coef coefs_{%i} = c
'store coeffecients
freeze(LRW_{%independent2}) nardl_{%i}.wald -c(4)/c(2) = -c(5)/c(2)
freeze(LR_{%independent2}_P) nardl_{%i}.wald -c(4)/c(2) = 0
freeze(LR_{%independent2}_N) nardl_{%i}.wald -c(5)/c(2) = 0
freeze(PSS_{%i}) nardl_{%i}.wald c(2) = c(3) = c(4)= c(5) = 0
next
else if !s=3 then
for %i {%dependent}
'****Model
equation nardl_{%i}.stepls(method = uni, back, btol = !sig) d({%i}) c {%i}(-1) {%independent1}_p(-1) {%independent1}_n(-1) {%independent2}_p(-1) {%independent2}_n(-1) @ d{%i}(-1 to -{!laglength}) d{%independent1}_p(-0 to -{!laglength}) d{%independent1}_n(-0 to -{!laglength}) d{%independent2}_p(-0 to -{!laglength}) d{%independent2}_n(-0 to -{!laglength})
coef coefs_{%i} = c
freeze(LRW_{%independent2}) nardl_{%i}.wald -c(5)/c(2) = -c(6)/c(2)
freeze(LR_{%independent1}_N) nardl_{%i}.wald -c(4)/c(2) = 0
freeze(LR_{%independent2}_P) nardl_{%i}.wald -c(5)/c(2) = 0
freeze(LR_{%independent2}_N) nardl_{%i}.wald -c(6)/c(2) = 0
freeze(PSS_{%i}) nardl_{%i}.wald c(2) = c(3) = c(4)= c(5) = c(6) = 0
next
else if !s=4 then
for %i {%dependent}
'****Model
equation nardl_{%i}.stepls(method = uni, back, btol = !sig) d({%i}) c {%i}(-1) {%independent1}(-1) {%independent2}(-1) {%independent3}_p(-1) {%independent3}_n(-1) @ d{%i}(-1 to -{!laglength}) d{%independent1}(-0 to -{!laglength}) d{%independent2}(-0 to -{!laglength}) d{%independent3}_p(-0 to -{!laglength}) d{%independent3}_n(-0 to -{!laglength})
coef coefs_{%i} = c
freeze(LRW_{%independent3}) nardl_{%i}.wald -c(5)/c(2) = -c(6)/c(2)
freeze(LR_{%independent3}_P) nardl_{%i}.wald -c(5)/c(2) = 0
freeze(LR_{%independent3}_N) nardl_{%i}.wald -c(6)/c(2) = 0
next
else if !s=5 then
for %i {%dependent}
'****Model
equation nardl_{%i}.stepls(method = uni, back, btol = !sig) d({%i}) c {%i}(-1) {%independent1}_p(-1) {%independent1}_n(-1) {%independent2}_p(-1) {%independent2}_n(-1) {%independent3}_p(-1) {%independent3}_n(-1) @ d{%i}(-1 to -{!laglength}) d{%independent1}_p(-0 to -{!laglength}) d{%independent1}_n(-0 to -{!laglength}) d{%independent2}_p(-0 to -{!laglength}) d{%independent2}_n(-0 to -{!laglength}) d{%independent3}_p(-0 to -{!laglength}) d{%independent3}_n(-0 to -{!laglength})
coef coefs_{%i} = c
freeze(LRW_{%independent3}) nardl_{%i}.wald -c(7)/c(2) = -c(8)/c(2)
freeze(LR_{%independent3}_P) nardl_{%i}.wald -c(7)/c(2) = 0
freeze(LR_{%independent3}_N) nardl_{%i}.wald -c(8)/c(2) = 0
freeze(PSS_{%i}) nardl_{%i}.wald c(2) = c(3) = c(4)= c(5) = c(6) = c(7) = c(8) = 0
next
endif
endif
endif
endif
endif
Sorry. What exactly is that? The data set has nothing in common with the Greenwood-Nimmo et al analysis and just offhand, the EViews code includes some techniques that aren't from that paper either.
Hi.
I am trying to use an one unknown threshold ARDL model which Cho et al. (2020) did in following paper.
"Recent Developments of the Autoregressive Distributed Lag Modelling Framework"
Is there any possibility if you can help me with the codes of TARDL with unknown threshold as I am new and have tried a lot to implement unknown TARDL but can not write code for unknown TARDL model. I would really appreciate your help and kind reply.
I followed the Hansen splitting method and so far find threshold and then I split my data around the threshold and then ran positive and negative regime separately by using ardl model. But problem is that since this is unknown threshold so we cannot use ardl or ols method and paper suggest to use QLR but I am stuck at this point and do not know how to use QLR for estimation and inference after finding threshold value.
Thanks in Advance
Thanks in Advance
Are there any updates on this thread? I need to implement a NARDL model similar to the one by Shin, Yu, and Greenwood (2014). It is available in R, Gauss, Stata, and EViews, but I was wondering if there is any code available in RATS for it.
Thank you.
Thank you.
Q-NARDL
I also am seeking code to run Q-NARDL models. Stata modules (plain text, free) have been posted on repec (https://ideas.repec.org/c/boc/bocode/s459736.html) but is there a Rats translation of the code?
