Shock in exogenous variables in a SVAR
torresgc
Hello. I could help. How I can generate shocks of 1% in the exogenous variables in a SVAR program?
Thanks for any help! (e-mail address: torresgc@bccr.fi.cr)
Re: Shock in exogenous variables in a SVAR
This may be a bit more than you need (it does MC integration for the response), but it shows the general idea. You create a placeholder equation which has the exogenous variable as its dependent variable, and shock that using the SHOCKS option on IMPULSE. To get 1%, you would use the optiontorresgc wrote:Hello. I could help. How I can generate shocks of 1% in the exogenous variables in a SVAR program?
shocks=.01*%unitv(%nvar+1,%nvar+1)
* Monte Carlo integration with shock to "exogenous" variable
compute lags=4 ;*Number of lags
compute nstep=16 ;*Number of response steps
compute ndraws=10000 ;*Number of keeper draws
open data haversample.rat
cal(q) 1959
data(format=rats) 1959:1 2006:4 ftb3 gdph ih cbhm
set loggdp = log(gdph)
set loginv = log(ih)
set logc = log(cbhm)
* T-Bill rate is treated as exogenous
system(model=varmodel)
variables loggdp loginv logc
lags 1 to lags
det constant ftb3{1 to 4}
* Define placeholder equation to allow shock to T-bills.
equation(empty) rateeq ftb3
estimate
compute nshocks=1
compute nvar =%nvar
compute fxx =%decomp(%xx)
compute fwish =%decomp(inv(%nobs*%sigma))
compute wishdof=%nobs-%nreg
declare vect[rect] %%responses(ndraws)
infobox(action=define,progress,lower=1,upper=ndraws) "Monte Carlo Integration"
do draw=1,ndraws
* On the odd values for <<draw>>, a draw is made from the inverse Wishart
* distribution for the covariance matrix. This assumes use of the
* Jeffrey's prior |S|^-(n+1)/2 where n is the number of equations in
* the VAR. The posterior for S with that prior is inverse Wishart with
* T-p d.f. (p = number of explanatory variables per equation) and
* covariance matrix inv(T(S-hat)).
* Given the draw for S, a draw is made for the coefficients by adding
* the mean from the least squares estimate to a draw from a
* multivariate Normal with (factor of) covariance matrix as the
* Kroneker product of the factor of the draw for S and a factor of
* the X'X^-1 from OLS.
* On even draws, the S is kept at the previous value, and the
* coefficient draw is reflected through the mean.
if %clock(draw,2)==1 {
compute sigmad =%ranwisharti(fwish,wishdof)
compute fsigma =%decomp(sigmad)
compute betau =%ranmvkron(fsigma,fxx)
else
* Push the draw for the coefficient back into the model.
* Shock the combination of the VAR + the placeholder equation with a
* unit shock to the placeholder.
impulse(noprint,model=varmodel+rateeq,shocks=%unitv(%nvar+1,%nvar+1),$
result=impulses,steps=nstep)
* Save the impulse responses
dim %%responses(draw)(nvar*nshocks,nstep)
infobox(current=draw)
end do draw
infobox(action=remove)
@mcgraphirf(model=varmodel,shocklabels=||"To Interest Rate"||)
Ozmando
Hi Everyone. I need more help with this code please. Is there a way to modify the code so that the impulse response functions graph only the response to the exogenous shocks? Thanks. Oz
That's what this does. The only shock analyzed is to the variable treated as exogenous.
Ozmando
TomDan thanks. However, I notice that the IFR of LOGC do not correspond to the estimates of the coefficients of FTB(?) They appear to be fine for other variables.TomDoan wrote:That's what this does. The only shock analyzed is to the variable treated as exogenous.
Look fine to me. LOGC is the only equation that has a negative coefficient on lag one of FTB3. Beyond lag one, it's very hard to tell what will happen just by eyeballing the coefficients.
Ozmando
More query please: if I read the data into rats into a panel format and I introduce country dummies as exogenous variables. Can that be treated as a panel SVAR? If not is there a way to estimate panel SVAR in the context of exogenous shocks?
oz
oz
In your panel SVAR, what's heterogeneous and what's homogeneous? What you're describing would seem to have only the intercepts being heterogeneous, which is a rather strong assumption, generally only appropriate if you have a limited amount of data per country. And if you have that, then the small-sample bias in the fixed effects estimator could be quite severe.
Ozmando
Hi Tom,TomDoan wrote:That's what this does. The only shock analyzed is to the variable treated as exogenous.
Sorry to bother again: If I am right the coefficients obtained are the mean response? is there away to also obtain the cumulative response (let's say after 3 period) and their confidence band?
Oz
Use the ACCUMULATE instruction. See, for instance, what the BQDODRAWS procedure does.
wfirew
I am estimating a vector error correction model (vecm) and a shock to the exogenous variable as described above does not work. Any suggestion?
Why not?wfirew wrote:I am estimating a vector error correction model (vecm) and a shock to the exogenous variable as described above does not work. Any suggestion?
wfirew
It works fine for VAR. Then, I have modified the code as follow for vecm (leaving the MC part). When I run it, the programs freezes prompting me to close the program.
I have one more concern that is dftb3 is just another exogenous variable instead of the difference of ftb3. But I want the difference of ftb3 outside the co-integrating vector as an exogenous while ftb3 is in the cointegrating vector.
cal(q) 1959
setset dftb3 = ftb3 - ftb3{1}
equation(coeffs=||1.0,0.3,0.3,0.3||) ect1
# loggdp loginv logc ftb3
system(model=vecmmodel)
lags 1 to lags
ect ect1
det constant dftb3{0 to 3}
estimate
impulse(noprint,model=vecmmodel+rateeq,shocks=%unitv(%nvar+1,%nvar+1),$
You need the %MODELSUBSTECT function as shown in this:
impulse(noprint,model=%modelsubstect(vecmmodel)+rateeq,shocks=%unitv(%nvar+1,%nvar+1),$
wfirew
Thanks for the quick response Tom,
It is working now. I have one question tough. I wanted to use short and long to identify other shocks. Therefore, I coded (using just sr restriction as an example) as attached below. Is this a correct way?
I know that it does not matter for the particular shock to the exogenous variable.
One last question which was not clearly put on the last post was about including the difference of ftb3 (the exogenous variable) in the VECM. Assuming ftb3 is I(1), I have to difference it before including it in the VECM where everything is I(0). But, the way I did it a shock to ftb3 does not affect dftb3 (=ftb3 - ftb3 {1})
I want a shock to ftb3 to also affect dftb3. How do I do that?
open data "C:\Program Files (x86)\Estima\WinRATS 7\haversample.rat"
cal(q) 1959
lags 1 to lags
ect ect1
estimate
dec rect lr(3,3) sr(3,3)
input lr
input sr
. . 0
. . 0
. 0 .
dec rect rh(1,4) rv(3,1)
input rv
0 0 0
input rh
0 0 0 1
dis rv rh
impulse(model=%modelsubstect(vecmmodel),factor=%identity(3),results=baseimp,noprint,steps=500)
compute lrsum=%xt(baseimp,500)
@ShortAndLong(lr=lr,sr=sr,masum=lrsum) %sigma f
compute f=f~rv~~rh
impulse(noprint,model=%modelsubstect(vecmmodel)+rateeq, factor=f, $
