Saving after using dedit
arian
Unread post by arian »
I am unable to save changes to series names while using dedit in RATS 8.1. I am able to execute the code sucessfully in RATS 7.1.
The code is:
dedit data.rat
rename x xyz
save
close dedit
When I open the dataset, the variable remains named "x". Running the exact same lines in version 7.1 executes perfectly. I have not been able to find any changes to the dedit instruction in the documentation, so it seems like I am using the correct commands. Does anyone have any input or possible solutions to this problem?
moderator
Site Admin
Re: Saving after using dedit
Unread post by moderator »
You need to use the QUIT instruction, not CLOSE, to close a file that has been opened using DEDIT. So, try using QUIT instead. If it still doesn't seem to work, email us at support@estima.com with your full contact information and we'll take a look.
Tom Maycock
