structural models for time series
I have some problems with the space state models, because it is the first time that I use the instrution dlm. I need to simulate one space state model. Someone can to help me.
The idea is to make a simulation a space state model, with factors no stationary and seasonal, errors have to a distribution noise white gaussian.
I don´t know how to use the instruction dlm for simulate. Please help me.
And I have a question about structural models, Do I use the same instruction? ¿How do I use the instrution dlm for this kind models?
Thanks for your help
Re: structural models for time series
What's your model? Write it in state-space form. Note, however, that if you're just trying to simulate a model, it's often easier to just do that directly. For instance, if you have a standard local level model:
x(t)=x(t-1)+w(t)
y(t)=x(t)+v(t)
where w(t) and u(t) are the shocks, the easiest way to do that is
To do the same thing with DLM, you would convert that to the state-space model
State equation:
x(t) = [1] x(t-1) + w(t)
Measurement equation:
y(t) = [1] x(t) + v(t)
An example would be:
x(t)=x(t-1)+w(t)
y(t)=x(t)+v(t)
allocate (# of data points you want)
set(first=0.0) x = x{1}+%ran(sigmaw)
set y = x+%ran(sigmav)State equation:
all 100
compute sigmav=2.0,sigmaw=1.0
dlm(a=1.0,c=1.0,sv=sigmav^2,sw=sigmaw^2,type=simulate,yhat=yhat)
set y = %scalar(yhat)Re: structural models for time series
Hello Tom,
Thanks for your help. I have two models:
The first one has factors no stationary:
y1t 1 0 f1t e1t
y2t = 0 1 * f2t + e2t
y3t 0 0 e3t
Where:
f1t, f2t: matrix (2x1) of the factors which have an ARIMA model.
e1t, e2t, e3t: matrix (2x1) of noise white Gaussian with distribution normal.
y1t, y2t, y3t: matrix (3X1) of observations
1 0 identity matrix (3x2)
0 1
0 0
The second one has a factor no stationary y other seasonal:
y1t = p11 0 * f1t + e1t
y2t = p21 p22 * f2t + e2t
Where
f1t, f2t: matrix (2x1) of the factors with f1t: is a factor with ARIMA model and f2t: is a factor with SARIMA model
e1t, e2t: matrix (2x1) noise white Gaussian with distribution normal.
y1t, y2t: matrix (2x1) observations
p11 0
p21 p22 loading matrix (2x2)
I need to simulate two models, I don´t have idea how do I use the instruction dlm for this kind of models?
y1t 1 0 f1t e1t
y3t 0 0 e3t
Where:
0 1
0 0
Where
p11 0
Again, it's simpler to simulate that in pieces rather than by trying to put together a state-space model with two observables and two separate state vectors. You would need something like this:
all 400
* This is the ARIMA model (1-L)(1-.4L)y=(1+.3L)u
equation(coeffs=||1.4,-.4,.3||,noconstant) arimaeq y 2 1
@armadlm(a=a1,f=f1,c=c1) arimaeq
* This is the "airline" SARIMA model (1-L)(1-L^12)y=(1-.7L)(1-.6L^12)u
equation(coeffs=||1.0,1.0,-1.0,-.7,-.6,.42||,noconstant,ar=||1,12,13||,ma=||1,12,13||) sarimaeq y
@armadlm(a=a2,f=f2,c=c2) sarimaeq
dlm(a=a1,f=f1,c=c1,yhat=fac1,sw=1.0,type=simulate,presample=ergodic)
dlm(a=a2,f=f2,c=c2,yhat=fac2,sw=4.0,type=simulate,presample=ergodic)
set e1 = %ran(2.0)
set e2 = %ran(0.5)
compute p11=1.0,p21=0.5,p22=1.0
set y1 = p11*fac1(t)(1)+e1
set y2 = p21*fac1(t)(1)+p22*fac2(t)(1)+e2 Re: structural models for time series
Hello Tom,
I have another question. I want to know, how do I remove the common trend for two series in RATS? I know that exist common trend in the series I need to remove in other to analyze the results.
This will extract a common H-P trend from a pair of series:mcorozcos wrote:Hello Tom,
http://www.estima.com/forum/viewtopic.php?f=8&t=1395
I need to create a code in RATS in order to retort the article that I attachment for apply the methodology to colombian data. I hope you can help me.
- Test seasonal integration and cointegration in multivariate unobserved component models 2004.pdf
- Article that I need to retort
- (588.91 KiB) Downloaded 1939 times
Hello Tom,
Can you help me with last post (sep 09)?
How far have you gotten on it? This is a paper with no citations in the literature, so it's clearly not in common use. It's not a particularly complicated state-space model, since it just has random walk coefficients on the deterministic seasonals, and the tests appear to be zero restrictions on the variances of those.
Hello Tom
Can you help to simulate this equation in Rats:
zt(h) = (cos λ(h)t, sin λ(h)t)'
Let s be the number of seasons and λ(h) = 2πh/s, h = 1, ..., [s/2], be the seasonal frequencies. Denote by zt(h), h = 1, ..., [s/2], the spectral indicator variable associated with each of the λ(h), that is zt(h) = (cos λ(h)t, sin λ(h)t)' for h < s/2 and, when s is even, zt(s/2) = cos λ(s/2)t = cos πt.
thanks for your help
regards
regards
Is there anything random about those? (I'm puzzled about the use of "simulate", since they appear to be deterministic).
Hello Tom,
Sorry, I make a mistake in my question, for this reason I make a new one.
I need to simulate some series with base at next structural model for time series:
yt = μt+st + εt,
μt = Xtβ,
st = sum of h = 1 to [s/2] of Zt(h)γt(h),
γt(h) = γt−1(h) + ηt(h), h= 1, ..., [s/2], is a random walk
ηt(h) ∼ IID (0, Σ η(h)) , h= 1, ..., [s/2],
εt ∼ IID (0, Σ ε) ,
where:
Xt = (IN ⊗ xt') ,
β =(β1', ..., βN')' ,
Zt(h) = (IN ⊗ zt(h)') ,
zt(h) = (cos λ(h)t, sin λ(h)t)0 for h < s/2 and, when s is even, zt(s/2) = cos λ(s/2)t = cos πt.
γt(h) =(γ1t(h)', ..., γNt(h)')' , h = 1, ..., [s/2].
ηt(h) is independent of ηs(l)l, i.e. the seasonal components at different frequencies are orthogonal, and also independent of the irregular disturbance εs, for all t, s; ⊗ denotes the Kronecker product.
S=be the number of seasons and
yt = μt+st + εt,
μt = Xtβ,
εt ∼ IID (0, Σ ε) ,
where:
Xt = (IN ⊗ xt') ,
The gamma's are the states, so the Z's will be the loadings (C's). Their notation is a bit odd, since they have a combination of 2-vectors and 1-vectors. This sets up the C formula:
dec vect[series] zt(s-1)
dec frml[vect] cf
do h=1,s/2
set zt(2*h-1) = cos(2*%pi*h*t/s)
if 2*h<=s-1
set zt(2*h) = sin(2*%pi*h*t/s)
end do h
frml cf = %xt(zt,t)Re: structural models for time series
Hello Tom,
Thanks for your help. I tried to do the last code, but it don´t show a vector of series that I need, for this reason I write you again.
I need to create a vector (100 rows,1 column) with simulated data for this equation:
st = summation of h=1 until h=[s/2] of Zt(h)
where, zt(h), is the spectral indicator variable associated with each of the λ(h), that is:
where s be the number of seasons and λ(h) = 2πh/s, h = 1, ..., [s/2], are the seasonal frequencies.
I hope, you can help me.
Thanks again.
Regards
Thanks again.
Regards
