loop using sstats
loop using sstats
I have a couple of series where I stored teststatistics over a rolling window. I do want to compute the share of entries where the value is below 0.1.
I would like to loop over series claw1uipuk to claw24uipuk and store the computed share in the vector vcw. The sstats command for a single series works well, but if I substitute the name
of the series by the loop index "s" it's not working anymore. Whats the error? By the way how do I know which series are inside the loop index. How does rats exactly know over which series to loop?
Is it also possible to loop overseries, where more then one element changes? For example dofor s= claw1uipuk to claw24tayuk, where uip also changes to tay.
compute count = 1
dofor s = claw1uipuk to claw24uipuk
sstats(mean) 2007:01 2011:12 1 (s<0.1)>> vcw(count)
compute count=count+1
end dofor
write vcw
Thanks a lot !
compute count = 1
end dofor
write vcw
Thanks a lot !
Re: loop using sstats
I don't know what the "1" is on this, and you need to get rid of the space between the >> and vcv(count)
However, the most important thing is that you need s{0}, not just s when s is an indirect reference to a series. That is, what you want is
sstats(mean) 2007:01 2011:12 (s{0}<0.1)>>vcw(count)
With that, it should work.
Dear Tom, I thank you for the quick and helpfull answers. It works.
I wanted to ask how rats is able to know over which series to loop. For example in stata I define a suffix "_i" to "_k" and I tell stata to loop over all series i to k. How does rats know, which series are included in the loop. Is it possible to loop over series where two items change at once? For example forecast_uk_1 to forecast_JP_3.
Thanks in advance!
Paul
Thanks in advance!
Paul
Assuming that those are the only series which have forecast_ as the prefix, you can do
dofor s = %slike("forecast_*")
end dofor s
If you are trying to restrict to a list built with combinations like UK_1 and JP_3, you would need to do a double loop over the country abbreviations and the horizons.
dofor [label] country = "UK" "DE" "CA" "JP"
dofor horizon = 1 2 3
compute s=%s("forecast_"+country+"_"+horizon)
end dofor horizon
end dofor label
end dofor s
end dofor horizon
end dofor label
