Is it possible to calculate simple correlation coefficient( not autocorreltioan) and its SIGNIFICNCE LEVEL between two series in RATS? Thanks.
sincerely,
msrahman.
simple correlation coeficient
Re: simple correlation coeficient
you can compute it in many ways. For instance:msrahman wrote:Is it possible to calculate simple correlation coefficient( not autocorreltioan) and its SIGNIFICNCE LEVEL between two series in RATS? Thanks.
sincerely,
msrahman.
cmom(corr)
# x y
disp %cmom(1,2)
As to the significance, what assumptions do you want to make? The standard asymptotics are that sqrt(%nobs)*rho~N(0,1) under the null of no correlation. You could also look at the F-statistic from a LINREG to Y on CONSTANT and X (or X on CONSTANT and Y) which will give a similar, but not identical value.
