Coviance of asymmetric Bivariate-GARCH models
wendyyuan
Post by wendyyuan »
Hey, Everyone,
I am programming asymmetric BI-GARCH models, such as GARCH-GJR, EGARCH, TGARCH. When we use Maximize command, we have to define the covariance formula. Anybody knows where can i find covariance equations?
Thanks a lot in advance
Re: Coviance of asymmetric Bivariate-GARCH models
You shouldn't be trying to use MAXIMIZE unless you have a model that you can't estimate using GARCH. Nothing you're describing appears to be outside the abilities of the GARCH instruction. I would note that you're also listing univariate models. EGARCH, for instance, isn't a well-defined bivariate procedure since it describes only the method used for the univariate variances. There are several ways to combine those into a covariance matrix (CC and DCC).
