Graph Format
AhmedSahlool
Graph Format
Unread post by AhmedSahlool »
I hope this finds you well,
Would you kindly tell me how to change the format of graphs generated by procedures like @MCGraphIRF. I would like to increase the font of vertical axis figures.
Thank you and best regards.
Re: Graph Format
Then change them. The following is in the procedure:
grparm(bold) hlabel 18 matrixlabels 14
grparm axislabel 24
Those are all relative to the size of the graph. If you find one too small, increase it.
AhmedSahlool
Re: Graph Format
Thank you for your reply.
And for the titles of the graphs, I would like to increase their size, they remain unchanged, when i change these parameters.
Thank you
Re: Graph Format
The header? You can add a change to the HEADER to the first of the two GRPARM's. The default is 24.
AhmedSahlool
Re: Graph Format
Yes, it's not what convenient to resort to one graph per page, but what could I do if I have graphs that I can't present in a word document, I tried to modify the options in the procedure @MCGraphIRF, but I still have graphs that I can't read one I copy to word, see attached.
I ended with grparm(bold) hlabel 60 matrixlabels 18
grparm axislabel 34
Would you give me some hints.
Thank you very much
IRF Graphs.docx
(20.21 KiB) Downloaded 871 times
Re: Graph Format
I suggested that you change the size of HEADER, not HLABEL. There are no HLABEL's in that graph.
AhmedSahlool
Re: Graph Format
Thank you.
and what about the lines of the graphs, how could I change their format?
Re: Graph Format
See section 3.16 of the RATS Introduction.
