Replacement for SMODIFY to reformulate VAR
mboldin
Unread post by mboldin »
I am updating old code (not written by me) that uses SMODIFY as a command on a VAR structure to create a small system out of a large equation system, where some series/equations will be treated as predetermined for a forecasting exercise.
I found out that SMODIFY is not in RATs 8.2, and I wonder if there is a replacement or SRC example that does what I need.
In essence a triangular contemporaneous relationship must be estimated (the structure VAR part) to transform the reduced form back to the structural system-- but only for 1/2 of the equations. I guess I could work out the effect using matrices to construct the new coefficients but did not want to re-invent something already prepared and tested.
Code example with smodify is below (I modified a few things to simplify). Note the estimations is BVAR, complicating things slightly.
system 1 to 4
variables y1 y2 y3 y4
lags 1 to 4
specify(tight=.20) .5
estimate(noprint) begdat  enddat
smodify(block=2) 4 v
# 1 11
# 2 12
# 3 13
# 4 14
forecast 2 8 begfor
# 13 fy3
# 14 fy4
Re: Replacement for SMODIFY to reformulate VAR
We actually have a fix for SMODIFY, which is still in the program but hadn't been tested for several versions. The following does the same transformation just using MODELS rather than numbered equations.
procedure SModify model0 model1
type model model0 *model1
option symm sigma
option int  block
local integer     neqn i j
local symm        wsigma
local rect[rect]  sblocks
local rect        rotate
local vect[equ]   workeq
compute neqn=%modelsize(model0)
if %defined(sigma)
   compute wsigma=sigma
else
   compute wsigma=%modelgetvcv(model0)
if %defined(block) {
   compute sblocks=%blocksplit(wsigma,||block,neqn-block||)
   compute rotate=-1.0*sblocks(2,1)*inv(sblocks(1,1))
   compute model1=%modeleqn(model0,1)
   do i=2,block
      compute model1=model1+%modeleqn(model0,i)
   dim workeq(neqn-block)
   do i=block+1,neqn
      compute workeq(i-block)=%modeleqn(model0,i)
      do j=1,block
         compute workeq(i-block)=workeq(i-block)+rotate(i-block,j)*$
            (%modeleqn(model0,j)-%eqnserieslag(%modeldepvars(model0)(j),0))
         disp workeq(i-block)
      compute model1=model1+workeq(i-block)
   compute %modelsetvcv(model1,%blockdiag(||sblocks(1,1),sblocks(2,2)+rotate*sblocks(1,2)||))
else {
   disp "Need BLOCK option"
   compute model1=model0
mboldin
Thanks Tom but Rats freezes and aborts when it gets to this line
I get a message box saying "A problem caused the program to stop working correctly. Please close the program"
same problem with using %smodify
