MV-EGARCH with spillovers
ibrahim
Re: MV-EGARCH with spillovers
Post by ibrahim »
Sorry about that, it is my miscoding,
Thank you so much Tom,
But after defining std residuals, for LB(Q) test I enter the below code
corr(qstats,number=12) z1
and then I got the below error
Works fine for me. Did you put this after the MAXIMIZE instruction?
There's an updated version which includes diagnostics at
http://www.estima.com/forum/viewtopic.php?f=8&t=1940
ibrahim
Post by ibrahim »
thank you so much Tom,
Best
pitsikiou
Post by pitsikiou »
i follow Koutmos code to estimate the spillover among 4 countries but instead of a var - egarch model i have to estimate an ecm multvariate egarch model.
What should i add in this code so as to estimate the ecm-mv-egarch ?
Thank you very much
The Koutmos paper does a VAR on the differences. The difference between that and a VECM is that the VECM requires an error correction term (or terms, depending upon the number of common trends). For instance, the following would create a single common trend for the four exchange rates:
(You can use any sets of pairs of the exchange rates in this).
set ect1 = 100*log(fra/ger)
set ect2 = 100*log(ger/ita)
set ect3 = 100*log(ita/uki)
equation meaneq *
# constant y(1){1} y(2){1} y(3){1} y(4){1} ect1{1} ect2{1} ect3{1}
pitsikiou
Post by pitsikiou »
You mean that i have to also write
set ect4 = 100*log (fra/ita)
set ect5 = 100*log (fra/uki)
set ect6 = 100*log (ger/uki)
in order to have the equation meaneq *
# constant y(1){1} y(2){1} y(3){1} y(4){1} ect1{1} ect2{1} ect3{1} ect4{1} ect5{1} ect6{1}???
I am sorry for the persistent quetions but i am working on my own the mv-ecm- egarch model so as to find the spillovers from each country to the other.
Thank you very much for your time
pitsikiou wrote:You mean that i have to also write
No. Half of those are redundant. If FRA-GER and GER-ITA are stationary then FRA-ITA has to be stationary as well. I was also just giving an example based upon the Koutmos data; if you have a different VECM, you would set it up differently.
Have you tried estimating the VECM without the GARCH errors? That's the place to start.
pitsikiou
Post by pitsikiou »
i completed the cointegration and found out that ger-uki: 1 cointegrating vector,ger-fra: 2 cointegrating vectors, ger-ita:2 cointegrationg vectors, fra-ita:2 coint.vect, fra-uki:2 coint. vec, ita-uki:2 coint vec
pitsikiou wrote:i completed the cointegration and found out that ger-uki: 1 cointegrating vector,ger-fra: 2 cointegrating vectors, ger-ita:2 cointegrationg vectors, fra-ita:2 coint.vect, fra-uki:2 coint. vec, ita-uki:2 coint vec
You're doing a four variable system, so you want to be looking at cointegration of the four variable system, not pairwise.
Also, don't you have theoretical values of the cointegrating vectors?
pitsikiou
Post by pitsikiou »
i did the cointegration for the 4 countries and johansen showed 2 cointegrated vectors but Max-eigenvalue test indicated no cointegration.
The ecm model gave me the following results
  Vector Error Correction Estimates
 Included observations: 95 after adjustments
 Standard errors in ( ) & t-statistics in [ ]
Cointegrating Eq: 	CointEq1
DEN(-1)	 1.000000
ESP(-1)	 0.172437
	 (0.21176)
	[ 0.81429]
FRA(-1)	-2.786610
	 (0.50725)
	[-5.49357]
GER(-1)	 1.524009
	 (0.42338)
	[ 3.59961]
C	-2.120413
Error Correction:	D(DEN)	D(ESP)	D(FRA)	D(GER)
CointEq1	-0.059121	 0.033942	 0.179201	-0.096106
	 (0.05115)	 (0.10068)	 (0.08450)	 (0.08959)
	[-1.15573]	[ 0.33714]	[ 2.12075]	[-1.07276]
D(DEN(-1))	 0.311850	-0.026134	-0.016336	-0.025765
	 (0.16200)	 (0.31883)	 (0.26760)	 (0.28372)
	[ 1.92497]	[-0.08197]	[-0.06104]	[-0.09081]
D(DEN(-2))	-0.024185	 0.154542	 0.087055	 0.348286
	 (0.14035)	 (0.27622)	 (0.23184)	 (0.24580)
	[-0.17232]	[ 0.55950]	[ 0.37550]	[ 1.41697]
D(ESP(-1))	 0.020153	 0.617986	 0.103380	 0.317499
	 (0.08371)	 (0.16476)	 (0.13828)	 (0.14661)
	[ 0.24073]	[ 3.75090]	[ 0.74759]	[ 2.16557]
D(ESP(-2))	 0.165803	-0.070239	 0.232540	 0.116802
	 (0.08412)	 (0.16556)	 (0.13895)	 (0.14732)
	[ 1.97102]	[-0.42426]	[ 1.67350]	[ 0.79283]
D(FRA(-1))	 0.009473	-0.103016	 0.257007	 0.089151
	 (0.13044)	 (0.25672)	 (0.21547)	 (0.22844)
	[ 0.07263]	[-0.40128]	[ 1.19278]	[ 0.39025]
D(FRA(-2))	-0.055491	-0.151846	-0.196705	-0.035067
	 (0.11648)	 (0.22924)	 (0.19241)	 (0.20399)
	[-0.47640]	[-0.66238]	[-1.02233]	[-0.17190]
D(GER(-1))	 0.159824	 0.045931	 0.208637	-0.123134
	 (0.10868)	 (0.21389)	 (0.17952)	 (0.19033)
	[ 1.47063]	[ 0.21475]	[ 1.16220]	[-0.64695]
D(GER(-2))	-0.135151	-0.314002	-0.254719	-0.309460
	 (0.10334)	 (0.20338)	 (0.17070)	 (0.18098)
	[-1.30785]	[-1.54393]	[-1.49220]	[-1.70992]
C	 0.166465	 0.162745	-0.074771	-0.067585
	 (0.39885)	 (0.78497)	 (0.65884)	 (0.69852)
	[ 0.41736]	[ 0.20733]	[-0.11349]	[-0.09676]
You're planning to do a multivariate GARCH model with only 95 data points? What kind of data do you have?
pitsikiou
Post by pitsikiou »
monthly data from 2006/01 - 2014/02 for 4 countries (98 observations for each country)
I seriously doubt that you're going to get reasonable results from running a complicated GARCH model with so little data. Have you run univariate GARCH models to see if there's even a GARCH effect to model?
pitsikiou
Post by pitsikiou »
yes i tested that and found out that garch effect exists in univariate garch for each country
