help for the 2 factor EGARCH
kingjia
please help
I already check the data delete all the data if it have hi<c<lo , hi=daily highest price, c= daily close price and lo= daily lowest price.
And also check out and delete the data if it have c(i)=c(i+1).
But still output error
## MAT13. Store into Out-of-Range Matrix or Series Element
The Error Occurred At Location 0788 of loop/block
Line 33 of loop/block
the code is below:
all 3876
open data X:\AUD.xls
data(format=xls,org=obs) /
close data
set lh / = log(hi)
set ll / = log(lo)
set r / = (((lh-ll)**2.0)/(4*log(2)))**0.5
SET Range = log(LH - LL)
SET Ret = LOG(C/C{1})
linreg(NOPRINT) Ret / E
#constant
comp tau2 = 240
comp tau1=fix(%max(1,tau2-19))
comp k=0
do i=500,5540-tau2,tau2
comp k=k+1
declare series u
declare series h
declare series Q
STATS(NOPRINT) RANGE
SET Q / = EXP(%MEAN)
SET H / = EXP(RANGE - 0.43)
SET U / = 0.0
nonlin A1 A3 A4 B1 B2 B3 B4
compute A1=0.5, A3=0.05,A4=-0.1, B1=1, B2=0.9,B3=0.05,B4=-0.1
frml res = (RANGE -0.43 -LOG(H))/0.29
frml QF = exp(B1+B2*log(Q{1})+B3*u{1} +B4*E{1}/h{1})
frml HF = exp(A1*LOG(Q{1})+(1-A1)*log(h{1}) +A3*u{1} +A4*E{1}/h{1})
frml logl = (h(t)=hf(t)),(q(t)=qf(t)),(u(t)=res(t)),-0.5*u(t)**2/.29**2
maximize(method=genetic,NOPRINT, iters=100) LOGL I-497 I
maximize(method=BFGS,NOPRINT, iters=100) LOGL I-497 I
set Q i+1 i+1 = exp(%BETA(4)+ %BETA(5)*LOG(Q(i))+%BETA(6)*u(i) + %BETA(7)*E(i)/h(i))
set H i+1 i+1 = exp(%BETA(1)*LOG(Q(i))+(1-%BETA(1))*log(h(i))+%BETA(2)*u(i) + %BETA(3)*E(i)/h(i))
do j =1,tau2
set ract j j = r(i+j)
set Q i+j+1 i+j+1 = EXP(%BETA(4) +%BETA(5)*log(Q(I+j)))
set H i+j+1 i+j+1 = EXP(%BETA(1)*LOG(Q(i+j))+(1-%BETA(1))*log(H(I+j)))
stat(noprint) ract tau1 tau2
set ractbar k k = %mean
stat(noprint) H tau1 tau2
set rforbar k k = %mean
linreg(noprint) ractbar 1 k
#constant rforbar
comp a=%beta(1);comp as=%stderrs(1)
comp b=%beta(2);comp bs=%stderrs(2)
comp rsq=%rsquared
test(noprint)
# 1 2
# 0.0 1.0
comp fstat=%cdstat
set error2 1 k = (ractbar-rforbar)**2.0
stat(noprint) error2 1 k
comp mse=(%mean*k/(k-1))**0.5
disp tau1 tau2 mse 100*a 100*as b bs rsq fstat
the code is below:
all 3876
close data
set lh / = log(hi)
set ll / = log(lo)
#constant
comp tau2 = 240
comp k=0
comp k=k+1
declare series u
declare series h
declare series Q
SET U / = 0.0
do j =1,tau2
#constant rforbar
comp rsq=%rsquared
test(noprint)
# 1 2
# 0.0 1.0
comp fstat=%cdstat
Re: help for the 2 factor EGARCH
Could you edit your post and paste in your program directly so it doesn't have all those blank lines. Also, once you have it pasted into the message, select the code and hit the "Code" button. It will make it easier to read.
kingjia
please help
I try to select the code then hit the code button, but it doesn't work,
I post a PRG file code, may it help?all 3876
close data
set lh / = log(hi)
set ll / = log(lo)
#constant
comp tau2 = 240
comp k=0
comp k=k+1
declare series u
declare series h
declare series Q
SET U / = 0.0
do j =1,tau2
#constant rforbar
comp rsq=%rsquared
test(noprint)
# 1 2
# 0.0 1.0
comp fstat=%cdstat
Line 33 of loop/block- Attachments
- 2f-var.PRG
- code
- (1.85 KiB) Downloaded 847 times
Why do you have all those blank lines in your program file?
Your loop is producing no output at all, so you don't know where it even is having the problem. At least put a DISPLAY I instruction in there so you can trace where the problem is.
kingjia
Dear tom
I am not understand what you mean of put a display, this is the data I used is not work out, I try to display
but just have error:
and I resent the code again , to help you delete those blank line:
hope this time you can read the code...
all 3876
close data
set lh / = log(hi)
set ll / = log(lo)
#constant
comp tau2 = 240
comp k=0
comp k=k+1
declare series u
declare series h
declare series Q
SET U / = 0.0
do j =1,tau2
#constant rforbar
comp rsq=%rsquared
test(noprint)
# 1 2
# 0.0 1.0
comp fstat=%cdstat
- AUD.xls
- 2F data
- (348.5 KiB) Downloaded 812 times
If you add the disp i instruction here
disp i
you'll see that it fails with I=4100. Since you have only 3876 data points, that's probably not a surprise.
disp i
kingjia
WOoooooo, it works. Cool.
thank you for your help, Tom.
