Note that MV=TBEKK (for triangular BEKK) and MV=DBEKK (for diagonal BEKK) were added to the GARCH instruction with RATS 8.3. Also, the SIGNS option was added to allow for different sign effects on asymmetry.
* Variations on BEKK models
all 6237
open data g10xrate.xls
data(format=xls,org=columns) / usxjpn usxfra usxsui
* Standard BEKK with GARCH instruction
compute gstart=3,gend=6237
garch(p=1,q=1,mv=bekk,pmethod=simplex,piters=5) gstart gend xjpn xfra xsui
* General setup for GARCH with MAXIMIZE
compute n=3
dec series[vect] yv
dec frml[vect] residv
dec vect[series] u(n)
* SERIES[SYMM] named H and UU. UX and HX are used for the current values
* of the residual vector and H matrices
declare series[symm] h uu
declare symm hx(n,n)
declare vect ux(n)
declare frml[symm] hf
* Mean parameters
dec vect mu(n)
nonlin(parmset=meanparms) mu
* Define residuals
frml residv = yv-mu
* Define vector of dependent variables
gset yv = ||xjpn,xfra,xsui||
* Run preliminary regression to get estimates of residuals and means.
nlsystem(frmlvector=residv,parmset=meanparms,resids=u) gstart gend
compute rr=%sigma
gset h * gend = rr
gset uu * gend = rr
frml logl = $
hx = h(t) = hf(t) , $
ux = residv , $
uu(t) = %outerxx(ux) , $
%pt(u,t,ux) , $
%logdensity(hx,ux)
* Standard BEKK. Should be the same as above (just much slower)
dec rect var(n,n) vbr(n,n)
dec packed vct(n,n)
dec symm vcs
compute var=sqrt(.05)*%identity(n),vbr=sqrt(.45)*%identity(n)
compute vct=%decomp(rr)
nonlin(parmset=bekkparms) vct var vbr
FUNCTION %%BEKKInit
compute vcs=%ltouterxx(vct)
END
frml hf = vcs+%mqform(h{1},vbr)+%mqform(uu{1},var)
maximize(title="Standard BEKK Model",start=%%BEKKInit(),parmset=meanparms+bekkparms,$
method=bfgs,iters=400,pmethod=simplex,piters=5) logl gstart gend
* Diagonal BEKK
dec vect vav(n) vbv(n)
dec packed vct(n,n)
dec symm vcs vbs vas
compute vav=%fill(n,1,sqrt(.05)),vbv=%fill(n,1,sqrt(.45))
nonlin(parmset=dbekkparms) vct vav vbv
FUNCTION %%DBEKKInit
compute vbs=%outerxx(vbv)
compute vas=%outerxx(vav)
END
maximize(title="Diagonal BEKK Model",start=%%DBEKKInit(),parmset=meanparms+dbekkparms,$
* Triangular BEKK. This is written assuming the "causality" flows from
* the first to the last series, which means that the A' matrix in A'HA
* needs to be lower triangular. Because of the convention used in
* defining "packed" matrices, the output will show A and B as lower
* triangular, so this is actually doing AHA' rather than A'HA.
dec packed vat(n,n) vbt(n,n)
dec packed vct(n,n)
compute vat=sqrt(.05)*%identity(n),vbt=sqrt(.45)*%identity(n)
nonlin(parmset=tbekkparms) vct vat vbt
FUNCTION %%TBEKKInit
local integer i j
ewise vbr(i,j)=%if(j>=i,vbt(i,j),0.0)
ewise var(i,j)=%if(j>=i,vat(i,j),0.0)
END
maximize(title="Triangular BEKK",start=%%TBEKKInit(),parmset=meanparms+tbekkparms,$
