Shocks in Two-variable Threshold VECM
TVolscho-286
Post by TVolscho-286 »
Here is a perhaps simpler one. Dataset attached. Two variables, Corporate Tax Return Audit Rate (Corp_a) and Unreported AGI/Reported AGI(UAG_RAG). My goal is to show a plot of UAG_RAG responding to a negative shock to Corp_a. In the VECM for the below-threshold ECT is statistically significant suggesting that UAG responds to below-threshold deviations from equilibrium.
I am getting the following error:
Forecast for DCORP_A solves to NA at 2010:01, on iteration 1
Forecast for DUAG_RAG solves to NA at 2010:01, on iteration 1...
linreg uag_rag / U
# constant  corp_a
set du = u-u{1}
linreg(title="Engle-Granger Auxiliary Regression") du
# u{1} du{1}
set tseries = u{1}
@EndersSiklos(title="TAR with Empirical Threshold", threshold=tseries, pi=.10, lags=1) u
set mt1 = %if(u{1}>=%%breakvalue,1,0)
set mt2 = 1-mt1
set z1 = mt1*u{1}
set z2 = mt2*u{1}
**z1 and z2, the two error correction terms are lagged above***
linreg du
# z1 z2 du{1}
set dcorpplus = %max(dcorp_a,0)
set dcorpminus = %min(dcorp_a,0)
set duag_ragplus = %max(duag_rag,0)
set duag_ragminus = %min(duag_rag,0)
        system(model=tvecm)
        variables dcorp_a duag_rag
        det dcorpplus{1} dcorpminus{1} duag_ragplus{1} duag_ragminus{1} z1 z2
        estimate
        frml(identity) duageq                uag_rag       = uag_rag{1}+duag_rag
        frml(identity) duag_ragpluseq        duag_ragplus  = %max(duag_rag,0)
        frml(identity) duag_ragminuseq       duag_ragminus = %min(duag_rag,0)
        frml(identity) corpeq                corp_a        = corp_a{1}+dcorp_a
        frml(identity) dcorp_apluseq         duplus        = %max(dcorp_a,0)
        frml(identity) dcorp_aminuseq        duminus       = %min(dcorp_a,0)
        frml(identity) zpluseq      zplus      =   z1
        frml(identity) zminuseq     zminus     =   z2
        group identities duageq corpeq duag_ragpluseq duag_ragminuseq $
        dcorp_apluseq dcorp_aminuseq
       compute fstart=%regend(),fend=fstart+9
       forecast(model=tvecm+identities,results=baseresults,steps=10)
* Do Choleski factor
        compute fsigma=%decomp(%sigma)
        * Do responses with + and - shocks to IM
        forecast(model=tvecm+identities,shocks = %xcol(fsigma,1),results=withplus,steps=10)
        forecast(model=tvecm+identities,shocks = -1.0*%xcol(fsigma,1),results=withminus,steps=10)
        * Take gap between the forecasts to get the IRF's
        ****Would the response OF UAG below be 3 or 4?***
        set ircorpplus fstart fend = withplus(3)-baseresults(3)
        set irfcorpminus fstart fend = withminus(3)-baseresults(3)
UAG Project.XLS
(6.83 KiB) Downloaded 1267 times
Re: Shocks in Two-variable Threshold VECM
As you have this written, Z1 and Z2 are exogenous (there's no formula in the model which creates them). I doubt that's what you want. Also, shouldn't you be using z1{1} and z2{1} in the model rather than contemporaneous values?
TVolscho-286
Here is a refinement of the code. I get an error for %%breakvalue when I try to create the zplus and zminus variables.
OPEN DATA "C:\Users\X201\Copy\Tax Evasion Paper\UAG Project.XLS"
DATA(FORMAT=XLS,ORG=COLUMNS) 1890:01 2013:01 YEAR CORP_A UAG_RAG
set duag_rag = uag_rag-uag_rag{1}
set dcorp_a = corp_a-corp_a{1}
     linreg uag_rag / U
     # constant  corp_a
      compute b=%beta
set du = u-u{1}
# u{1} du{1}
set tseries = u{1}
     set zplus  = %max(uag_rag-b(1)-b(2)*corp_a -%%breakvalue,0.0)
     set zminus = %min(uag_rag-b(1)-b(2)*corp_a -%%breakvalue,0.0)
               system(model=tvecm)
               det dcorpplus{1} dcorpminus{1} duag_ragplus{1} duag_ragminus{1} zplus{1} zminus{1}
               estimate
        frml(identity) zpluseq               zplus         = %max(uag_rag-b(1)-b(2)*corp_a-%breakvalue,0.0)
        frml(identity) zminuseq              zminus        = %min(uag_rag-b(1)-b(2)*corp_a-%breakvalue,0.0)
       compute fstart=%regend(),fend=fstart+5
       forecast(model=tvecm+identities,results=baseresults,steps=6)
        forecast(model=tvecm+identities,shocks = %xcol(fsigma,1),results=withplus,steps=6)
        forecast(model=tvecm+identities,shocks = -1.0*%xcol(fsigma,1),results=withminus,steps=6)
        set irfcorpplus fstart fend = withplus(3)-baseresults(3)
You're using %breakvalue (without %%) when you're defining the formulas.
TVolscho-286
Even when I put the double %, I am still getting the following error:
## SX11. Identifier %%BREAKVALUE is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>rp_a -%%breakvalue,<<<<
I should note that this error comes after trying to set ZPLUS and ZMINUS (right after estimating the TAR with Enders-Siklos)
1. You're missing your cal(a) 1890 instruction
2. That can't happen if you execute the @ENDERSSIKLOS procedure so somehow you're not executing everything when you get that error.
3. You didn't include the identities defining ZPLUS and ZMINUS in your IDENTITIES group.
TVolscho-286
I made sure the Cal(A) (it is annual data) instruction was included. I am still getting the same error
OPEN DATA "UAG Project.xlsx"
CALENDAR(A) 1890:1
DATA(FORMAT=XLSX,ORG=COLUMNS) 1890:01 2013:01 YEAR CORP_A UAG_RAG
     linreg uag_rag / U
     # constant  corp_a
      compute b=%beta
set du = u-u{1}
# u{1} du{1}
set tseries = u{1}
     set zplus  = %max(uag_rag-b(1)-b(2)*corp_a - %%breakvalue,0.0)
     set zminus = %min(uag_rag-b(1)-b(2)*corp_a - %%breakvalue,0.0)
               system(model=tvecm)
               estimate
        frml(identity) zpluseq               zplus         = %max(uag_rag-b(1)-b(2)*corp_a-%%breakvalue,0.0)
        frml(identity) zminuseq              zminus        = %min(uag_rag-b(1)-b(2)*corp_a-%%breakvalue,0.0)
        dcorp_apluseq dcorp_aminuseq zpluseq zminuseq
UAG Project.xlsx
(10.32 KiB) Downloaded 1090 times
You changed up your data series, but missed the change to the series name in the 2nd and 3rd equations:
Those need to be dcorpxxxx not duxxxx.
TVolscho-286
success...thank for your time and patience in spotting the mistakes. Here is the code that works.
Just an informational question. In the last two lines of codes, since I have (3) in the brackets, is that the response of Corp_a or UAG_RAG? I would assume it is the response of Corp_a to UAG?
    OPEN DATA "C:\Users\Administrator\Copy\Tax Evasion Paper\UAG Project.xlsx"
    CALENDAR(A) 1890:1
         linreg uag_rag / U
         # constant  corp_a
          compute b=%beta
    set du = u-u{1}
    # u{1} du{1}
    set tseries = u{1}
                   system(model=tvecm)
                   estimate
            frml(identity) dcorp_apluseq         dcorpplus        = %max(dcorp_a,0)
            frml(identity) dcorp_aminuseq        dcorpminus       = %min(dcorp_a,0)
            * Do responses with + and - shocks to Corp_a
UAG_RAG. (If you put a PRINT option on one of the FORECAST instructions, you can see the order). With two variables in the TVECM, (3) will be the dependent variable in the first identity in the IDENTITIES group.
TVolscho-286
Very helpful! Thanks again!
