help with code
allister
help with code
Hi Tom I am posting a code that i want you to look over for me it uses the conditional forecast src function. I am getting a bit of trouble with the code can you just look it over for me and correct any mistakes in it for me please. I am attaching the code and the data.
- indexsa.xls
- (132.18 KiB) Downloaded 946 times
- BVAR_IRF_tvc_condfor.PRG
- (7.89 KiB) Downloaded 952 times
Re: help with code
Correct what mistakes? It's using the older cndition.src file rather than the newer condition.src? Are you missing that? I've attached a copy. Other than that, it seems fine.
- cndition.src
- (3.72 KiB) Downloaded 819 times
