Well, the code is quite long. Sorry for that. I first estimate several models and save the corresponding forecasting erros. The ext step is then the part where I generate and save the mean absolute errors for each model for several time periods.
* AR - VERGLEICHSMODELL *
dofor i = laenderFP
comp preg=1, steps=4, kontemp=1, fsteps=4
declare rectangular[series] forcerrorAR(47,steps) absforcerrorAR(47,steps) forcAR(47,steps)
clear forcerror absforcerror forconestep1 forconestepar
do ftime = 2003:1,2012:4
estimate(model=mar(i),noprint) 1985:1 ftime-1
forecast(model=mar(i),print=preg,result=forc1) * fsteps ftime
* PROGNOSEFEHLER AR-MODELL
do fsteps=1,steps
set forcAR(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = forc1(1)(t)
set forcerrorAR(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = ( dexport(i)(t) - forc1(1)(t) )**2
set absforcerrorAR(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = abs( dexport(i)(t) - forc1(1)(t) )
end do fsteps
end do ftime
end dofor i
disp i
* FUTURE PRODUCTION INDEX
dofor i = laenderFP
declare rectangular[series] forcerrorFP(47,steps) absforcerrorFP(47,steps) forcFP(47,steps)
estimate(model=mexpfp(i)) 1985:1 ftime-1
forecast(model=mexpfp(i),print,result=forc2) * fsteps ftime
if kontemp==1 {
forecast(input,model=mexpfp(i),print,result=forc2) * fsteps ftime
# 0 fp(i)(ftime)-forc2(2)(ftime)
do fsteps=1,steps
set forcFP(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = forc2(1)(t)
set forcerrorFP(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = ( dexport(i)(t) - forc2(1)(t) )**2
set absforcerrorFP(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = abs( dexport(i)(t) - forc2(1)(t) )
end do fsteps
end do ftime
end dofor i
disp i
* EUC EXPORT EXPECTATIONS
dofor i = laenderEC
declare rectangular[series] forcerrorEC(47,steps) absforcerrorEC(47,steps) forcEC(47,steps)
estimate(model=mexpec(i)) 1985:1 ftime-1
forecast(model=mexpec(i),print,result=forc3) * fsteps ftime
if kontemp==1 {
forecast(input,model=mexpec(i),print,result=forc3) * fsteps ftime
# 0 expec(i)(ftime)-forc3(2)(ftime)
do fsteps=1,steps
set forcEC(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = forc3(1)(t)
set forcerrorEC(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = ( dexport(i)(t) - forc3(1)(t) )**2
set absforcerrorEC(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = abs( dexport(i)(t) - forc3(1)(t) )
end do fsteps
end do ftime
end dofor i
disp i
* FP-INDEX & EUC EXPORT EXPECTATIONS
dofor i = laenderEC
declare rectangular[series] forcerrorALL(47,steps) absforcerrorALL(47,steps) forcALL(47,steps)
estimate(model=mexpall(i)) 1985:1 ftime-1
forecast(model=mexpall(i),print,result=forc4) * fsteps ftime
if kontemp==1 {
forecast(input,model=mexpall(i),print,result=forc4) * fsteps ftime
# 0 fp(i)(ftime)-forc2(2)(ftime) 0 expec(i)(ftime)-forc3(2)(ftime)
do fsteps=1,steps
set forcALL(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = forc4(1)(t)
set forcerrorALL(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = ( dexport(i)(t) - forc4(1)(t) )**2
set absforcerrorALL(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = abs( dexport(i)(t) - forc4(1)(t) )
end do fsteps
end do ftime
end dofor i
disp i
* NEW ORDERS (USA)
dofor i = laenderNO
declare rectangular[series] forcerrorNO(47,steps) absforcerrorNO(47,steps) forcNO(47,steps)
estimate(model=mexpno(i)) 1985:1 ftime-1
forecast(model=mexpno(i),print,result=forc5) * fsteps ftime
if kontemp==1 {
forecast(input,model=mexpno(i),print,result=forc5) * fsteps ftime
# 0 neworder(i)(ftime)-forc5(2)(ftime)
do fsteps=1,steps
set forcNO(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = forc5(1)(t)
set forcerrorNO(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = ( dexport(i)(t) - forc5(1)(t) )**2
set absforcerrorNO(i,fsteps) ftime+fsteps-1 ftime+fsteps-1 = abs( dexport(i)(t) - forc5(1)(t) )
end do fsteps
end do ftime
end dofor i
disp i
*** SAVE MEAN ABSOLUTE ERRORS ***
*** AR-MODEL ***
dec rec[real] MAEAR(47,steps+1) MAE03AR(47,steps+1) MAE08AR(47,steps+1)
dofor i = laenderFP
comp MAEAR(i,1) = i, MAE03AR(i,1) = i, MAE08AR(i,1) = i
do fsteps = 1,fsteps
statistics(noprint) absforcerrorAR(i,fsteps) 2003:1 2007:4 ; comp MAE03AR(i,fsteps+1)=%mean
statistics(noprint) absforcerrorAR(i,fsteps) 2008:1 2012:4 ; comp MAE08AR(i,fsteps+1)=%mean
statistics(noprint) absforcerrorAR(i,fsteps) 2003:1 2012:4 ; comp MAEAR(i,fsteps+1)=%mean
end do fsteps
end dofor i
*** FP-INDEX ***
dec rec[real] MAEFP(47,steps+1) MAE03FP(47,steps+1) MAE08FP(47,steps+1)
dofor i = laenderFP
comp MAEFP(i,1) = i, MAE03FP(i,1) = i, MAE08FP(i,1) = i
statistics(noprint) absforcerrorFP(i,fsteps) 2003:1 2007:4 ; comp MAE03FP(i,fsteps+1)=%mean
statistics(noprint) absforcerrorFP(i,fsteps) 2008:1 2012:4 ; comp MAE08FP(i,fsteps+1)=%mean
statistics(noprint) absforcerrorFP(i,fsteps) 2003:1 2012:4 ; comp MAEFP(i,fsteps+1)=%mean
end do fsteps
end dofor i
*** EUC EXPORT EXPECTAIONS ***
dec rec[real] MAEEC(47,steps+1) MAE03EC(47,steps+1) MAE08EC(47,steps+1)
dofor i = laenderEC
comp MAEEC(i,1) = i, MAE03EC(i,1) = i, MAE08EC(i,1) = i
statistics(noprint) absforcerrorEC(i,fsteps) 2003:1 2007:4 ; comp MAE03EC(i,fsteps+1)=%mean
statistics(noprint) absforcerrorEC(i,fsteps) 2008:1 2012:4 ; comp MAE08EC(i,fsteps+1)=%mean
statistics(noprint) absforcerrorEC(i,fsteps) 2003:1 2012:4 ; comp MAEEC(i,fsteps+1)=%mean
end do fsteps
end dofor i
*** FP-INDEX & EXPORT EXPECTATIONS ***
dec rec[real] MAEALL(47,steps+1) MAE03ALL(47,steps+1) MAE08ALL(47,steps+1)
dofor i = laenderEC
comp MAEALL(i,1) = i, MAE03ALL(i,1) = i, MAE08ALL(i,1) = i
statistics(noprint) absforcerrorALL(i,fsteps) 2003:1 2007:4 ; comp MAE03ALL(i,fsteps+1)=%mean
statistics(noprint) absforcerrorALL(i,fsteps) 2008:1 2012:4 ; comp MAE08ALL(i,fsteps+1)=%mean
statistics(noprint) absforcerrorALL(i,fsteps) 2003:1 2012:4 ; comp MAEALL(i,fsteps+1)=%mean
end do fsteps
end dofor i
*** NEW ORDERS ***
dec rec[real] MAENO(47,steps+1) MAE03NO(47,steps+1) MAE08NO(47,steps+1)
dofor i = laenderNO
comp MAENO(i,1) = i, MAE03NO(i,1) = i, MAE08NO(i,1) = i
statistics(noprint) absforcerrorNO(i,fsteps) 2003:1 2007:4 ; comp MAE03NO(i,fsteps+1)=%mean
statistics(noprint) absforcerrorNO(i,fsteps) 2008:1 2012:4 ; comp MAE08NO(i,fsteps+1)=%mean
statistics(noprint) absforcerrorNO(i,fsteps) 2003:1 2012:4 ; comp MAENO(i,fsteps+1)=%mean
end do fsteps
end dofor i
