Dear Dr Thomas Doan
Thank you very much for your reply. But the thing is that I cannot figure out the what estimates comes from what parameters from Rats output. For example the positions: 1,2, 10,11 and 3,4, 12,13 from the below output from VARMA (1,1)- GARCHM-assymetric BEKK (data is the same as my previous attachment).
Moreover, I'd like to have Q^2(12) for the joint standardized residuals but I don't know what is the command. That is the reason I get the z1sq and z2sq to have their Q^2(12) values. But as your comments, this command is for individual series only. Can you tell me the command for the square Q of zu?
Since I'm very new with RATs, I don't know much even the basic thing of RATs. But I need this program for my project so could you please answer this question? (i will invest in RATs later)
If I want to change from VARMA(1,1) to VARMA(1,2), is it correct that I change from: (due to auto correlation problem, if any)
system(model=varmah)
variables rbmindo rbmus
lags 1 1
det constant eps(1){1} eps(2){1} sqrth(1) sqrth(2)
TO
lags 1 2
det constant eps(1){1} eps(2){1} eps(1){2} eps(2){2} sqrth(1) sqrth(2)
Can you suggest me the topic that I can learn to define the output coefficients and their parameters? (since VARMA (1,2) has more variables than VARMA (1,1) and that make me more confuse) or do you have any documents about reading output from this model?
Thank you very much.
Hung
Convergence in 144 Iterations. Final criterion was 0.0000000 <= 0.0000100
Daily(5) Data From 2000:01:05 To 2014:01:31
Usable Observations 3673
Log Likelihood -14117.1307
1. RBMINDO{1} 0.311383487 0.123336861 2.52466 0.01158107
2. RBMINDO{1} 0.345268102 0.123336839 2.79939 0.00511990
3. RBMUS{1} 2.273218103 0.492027469 4.62010 0.00000384
4. RBMUS{1} 2.338340113 0.492027589 4.75246 0.00000201
5. Constant 0.560564252 0.288827317 1.94083 0.05227910
6. EPS(1){1} -0.633765161 0.243799255 -2.59954 0.00933496
7. EPS(2){1} -4.361230660 0.988603479 -4.41151 0.00001027
8. SQRTH(1) 0.176945115 0.152684677 1.15889 0.24650004
9. SQRTH(2) -0.803733369 0.244817367 -3.28299 0.00102712
10. RBMINDO{1} -0.024388008 0.024668329 -0.98864 0.32284107
11. RBMINDO{1} 0.034640429 0.024668379 1.40424 0.16024614
12. RBMUS{1} -0.126791657 0.132139574 -0.95953 0.33729269
13. RBMUS{1} -0.141509938 0.132139575 -1.07091 0.28420873
14. Constant -0.144940873 0.082123036 -1.76492 0.07757663
15. EPS(1){1} -0.015533750 0.046773251 -0.33211 0.73980805
16. EPS(2){1} 0.243152151 0.256817926 0.94679 0.34374678
17. SQRTH(1) -0.043947712 0.040160976 -1.09429 0.27382826
18. SQRTH(2) 0.213146403 0.062841602 3.39180 0.00069434
19. C(1,1) 0.434529472 0.046635270 9.31761 0.00000000
20. C(2,1) 0.036463757 0.034476537 1.05764 0.29021970
21. C(2,2) 0.183498895 0.019398861 9.45926 0.00000000
22. A(1,1) 0.248594174 0.019926473 12.47557 0.00000000
23. A(1,2) 0.001927515 0.014875560 0.12958 0.89690193
24. A(2,1) 0.157618868 0.027684019 5.69350 0.00000001
25. A(2,2) -0.106060741 0.026567869 -3.99207 0.00006550
26. B(1,1) 0.908483168 0.012498979 72.68459 0.00000000
27. B(1,2) -0.009859188 0.009696187 -1.01681 0.30924340
28. B(2,1) 0.014282629 0.007899892 1.80795 0.07061391
29. B(2,2) 0.962616424 0.004448899 216.37182 0.00000000
30. D(1,1) 0.265637079 0.031578858 8.41186 0.00000000
31. D(1,2) 0.015432905 0.018213977 0.84731 0.39682174
32. D(2,1) 0.082562284 0.038128569 2.16537 0.03035971
33. D(2,2) 0.305978699 0.020761504 14.73779 0.00000000
Independence Tests for Series Z1
Test Statistic P-Value
Ljung-Box Q(121) 150.52772 0.0356
McLeod-Li(121) 129.85193 0.2748
Turning Points -0.16962 0.8653
Difference Sign -0.85726 0.3913
Rank Test -0.74547 0.4560
Independence Tests for Series Z2
Ljung-Box Q(121) 121.32039 0.4747
McLeod-Li(121) 119.83000 0.5130
Turning Points -0.56105 0.5748
Difference Sign -1.77167 0.0764
Rank Test 1.84968 0.0644
Multivariate Q(12)= 50.78402
Significance Level as Chi-Squared(48)= 0.36444
