Anzuini, Lombardi and Pagano (2013, IJCB)
Hi, I'm a complete novice with the RATS software and am having a few issues trying to replicate the model in Anzuini, Lombardi and Pagano (2013, IJCB)- The Impact of Monetary Policy Shocks on Commodity Prices. The structural identification used in their paper is based on Kim (1999) after identifying the monetary policy shock the marginal method is used to trace the response of an individual commodity price [Both specifications can be found here: http://postimg.org/image/bm0txte8p/].
I have attempted to code a CVMODEL based on the helpful examples and some of the threads in the forums but I am having a few issues getting beyond the first identification scheme [my code is attached]. I would really appreciate some help with regards to the issues in my code and how I would go about moving from identifying the shock to adding in the individual commodity prices and tracing the price response. Thanks in advance!
- Anzuini.rtf
- (1.16 KiB) Downloaded 804 times
Re: Anzuini, Lombardi and Pagano (2013, IJCB)
That looks fine. Did you Select All and Run or did you try to execute a line at a time? The latter isn't generally a good idea with already written programs as it's really easy for execution to get behind and miss a line.
I was executing line by line! I will try to run the whole thing when I get back to my desktop.
I've edited the code for Uhlig(2005) sign restricted irfs [Uhlig2.rpf] to match the Anzuini VAR specification. However, the literature generally shows the irfs to 100 basis point monetary policy shocks. How would I go about specifying the size of the impulse in the code?
The following would standardize the shock in the uhlig2.rpf program to be unit impact on the interest rate series (# 4 in the model). Note that you can't use the standardized shocks for doing the FEVD. (The first and last are already existing---the comments and the compute [vector] ... need to be added).
dim goodresp(accept)(i,j)=...
* Standardize shock to unit on interest rate
compute [vector] impact=%xt(impulses,1)*a,a=a/impact(4)
ewise goodresp(accept)(i,j)=...
Just what I was after! Thanks
To follow up on the first entry in this thread, I am posting below my coding attempt at replicating Anzuini, Lombardi and Pagano (2013). Sepcifically, the code below modifies MONTEVAR.RPF (After reading a number of Tom's responses on the forum) to obtain the responses to a negative 100 basis point decrease in the Federal funds rate (FFR) (as the authors do) along with their Confidence Intervals. The MONTEVAR.RPF is modified using: to obtain a one unit shock (1%) to the FFR and as well as: to obtain the negative FFR shock. Given that I reconstructed the authors' data, the magnitudes of the responses are off (so is the shape for the CPI and the commodity price index). The responses I obtain are attached. I am posting this just in case it is useful for those of you trying to work with the paper's VAR model.
compute fsigma2 = fsigma*inv(%diag(%xdiag(fsigma)))Code: Select all
compute flipper = ||-1.0,1.0,1.0,1.0,1.0||Code: Select all
compute fsigma3 = fsigma2*%diag(flipper)Code: Select all
* MONTEVAR.RPF for Anzuini, Lombardi and Pagano (2013)
* RATS Version 8, User's Guide, Example 16.2
* Monte Carlo Integration of Impulse Responses
compute lags=12 ;*Number of lags
compute nstep=50 ;*Number of response steps
compute ndraws=10000 ;*Number of keeper draws
calendar(m) 1970:01
allocate 2008:12
OPEN DATA "C:\Replications VAR Commodities\Anzuini, Lombardi and Pagano (2013)\ALP_Data.xlsx"
DATA(FORMAT=XLSX,ORG=COLUMNS) 1970:01 2008:12 CPI FFR IP M2 CRB_BLS Oil
**Obtain log levels of variables
set lm2 = log(m2)
set lcpi = log(cpi)
set lcrb = log(crb_bls)
set lip = log(ip)
system(model=varmodel)
variables ffr lip lm2 lcpi lcrb
lags 1 to lags
estimate(noprint)
compute nvar =%nvar
compute fxx =%decomp(%xx)
compute fwish =%decomp(inv(%nobs*%sigma))
compute wishdof=%nobs-%nreg
dec frml[rect] afrml
nonlin g12 g15 g21 g23 g24 g34 g51 g52 g53 g54
frml afrml = || 1.0, g12, 0.0, 0.0, g15|$
g21, 1.0, g23, g24, 0.0|$
0.0, 0.0, 1.0, g34, 0.0|$
0.0, 0.0, 0.0, 1.0, 0.0|$
g51, g52, g53, g54, 1.0||
cvmodel(a=afrml,method=bfgs,iters=1000,factor=fsigma) %sigma
declare rect[series] impulses(nvar,nvar)
infobox(action=define,progress,lower=1,upper=ndraws) "Monte Carlo Integration"
do draw=1,ndraws
* On the odd values for <<draw>>, a draw is made from the inverse Wishart
* distribution for the covariance matrix. This assumes use of the
* Jeffrey's prior |S|^-(n+1)/2 where n is the number of equations in
* the VAR. The posterior for S with that prior is inverse Wishart with
* T-p d.f. (p = number of explanatory variables per equation) and
* covariance matrix inv(T(S-hat)).
* Given the draw for S, a draw is made for the coefficients by adding
* the mean from the least squares estimate to a draw from a
* multivariate Normal with (factor of) covariance matrix as the
* Kroneker product of the factor of the draw for S and a factor of
* the X'X^-1 from OLS.
* On even draws, the S is kept at the previous value, and the
* coefficient draw is reflected through the mean.
if %clock(draw,2)==1 {
compute sigmad =%ranwisharti(fwish,wishdof)
compute fsigma =%decomp(sigmad)
compute betau =%ranmvkron(fsigma,fxx)
else
* Push the draw for the coefficient back into the model.
impulse(noprint,model=varmodel,factor=fsigma3,$
results=impulses,steps=nstep)
* Save the impulse responses
dim %%responses(draw)(nvar*nvar,nstep)
infobox(current=draw)
end do draw
infobox(action=remove)
@mcgraphirf(model=varmodel,page=byshock)
- ALP_responses.pdf
- (85.6 KiB) Downloaded 760 times
