Unbalanced panel data
b_lobo
I am trying to create a balanced panel dataset. Attached is a sample XLS file with 4 cross-sections or firms. The total time periods should be 191 months from 1998:6 through 2014:4. Thus I need a balanced panel of 4 x 191 = 764 obs.
The data are stacked by firm and each firm has is indexed by "Firm_no". Here is what I am doing:
CALENDAR(M) 1998:6
ALL 2014:4
open data sample.xls
data(format=xls,org=obs) / event date Firm_No Estimate Actual
*** TRANSFORMING TO A BALANCED PANEL ***********
* this is an unbalanced panel with 4 blocks (cross sections/firms)
* I need 191 obs for each bloc including missing obs
PFORM(indiv=event) PESTIMATE
# ESTIMATE
PFORM(indiv=event) PACTUAL
# ACTUAL
**** CHANGE TO PANEL DATA CALENDAR *****
CAL(PANELOBS=191) 1998:6
ALL 4//191
COPY(format=rats) / pactual pestimate
This doesn't seem to be doing it for me. What am I doing incorrectly?
CALENDAR(M) 1998:6
ALL 2014:4
# ESTIMATE
# ACTUAL
ALL 4//191
- sample.xls
- (38.5 KiB) Downloaded 934 times
Re: Unbalanced panel data
Perhaps I'm not understanding what you're trying to do, but it seems to me that firm_no should be representing individuals, rather than event. Plus, you need to use both the INDIV and TIME options on PFORM to get the observations to line up. Also, the original data aren't monthly---it's a stack of four time series with gaps in them. Also, even across all the firms you don't have 191 time series observations. The following will block what you actually have into a 4 x 163 panel.
data(format=xls,org=obs) / event Firm_No Estimate Actual
PFORM(indiv=firm_no,time=event) PESTIMATE
# ESTIMATE
PFORM(indiv=firm_no,time=event) PACTUAL
# ACTUAL
CAL(PANELOBS=%nobs)
ALL %ngroup//%nobs
# ESTIMATE
# ACTUAL
CAL(PANELOBS=%nobs)
ALL %ngroup//%nobs
b_lobo
Thank you. Doing this generates 163 obs for firms 1, 2 and 3 but only 56 obs for firm 4. Also the start event for each firm is different. I'm trying to get all the firms to start with event #1 and end with event #191 i.e. a total of 4 x 191 = 764 rows of data including missing obs. Any thoughts?
Put a hard range on the COPY instruction as 1//1 4//163. The default range will truncate the last firm at its last data point.b_lobo wrote: Thank you. Doing this generates 163 obs for firms 1, 2 and 3 but only 56 obs for firm 4.
Your data set has no event number less than 26. What are 1-25 supposed to be?b_lobo wrote: Also the start event for each firm is different. I'm trying to get all the firms to start with event #1 and end with event #191 i.e. a total of 4 x 191 = 764 rows of data including missing obs. Any thoughts?
b_lobo
This is a small sample from a bigger file. There are other cross sections that start at event #1. For firms that don't have obs for event #1, I'd like the missing obs code to show. No firm in the entire file has all 191 obs, so I expect that all the cross sections will have some missing obs. I'm setting up the file in case I need to run random effects or other variations with this dataset.
PFORM doesn't invent identifiers that don't exist. When you use a bigger file that has event numbers from 1 to 191, you'll get 191 per individual.
