How to deal with zeros in data?
Aixia_Mei
Unread post by Aixia_Mei »
I've posted before, but I still get questions about how to deal with 0s in the data set.
My research aims to figure out the influence of the introduction of short selling on feedback trading and volatility in Chinese stock market. As can be seen in the excel document, there are many zeros in the time series of each stocks' log return. Specifically, for those zeros that are in a row for all object stocks , it is because China sometimes has short-term national holidays.While for successive zeros in a column of individual stocks, it could be explained as a period of stock suspension due to the company's own operation problem. So both of these two types of zeros actually means non-trading days.
As you suggested, I've tried to delete the first type of zeros, those 4 or 5 zeros in a row, but the results seem still weird. There is always a no convergence problem. Could you please help me to have a look?
The input codes are as follows:
OPEN DATA "C:\Users\aixia\Desktop\51 Return_xls.xls"
CALENDAR(D) 2006:04:03
DATA(FORMAT=XLS,ORG=COLUMNS,RIGHT=2) 2006:04:03 2014:03:31 PUDONG
set r1 = PUDONG
nonlin b0 b1 b2 b3 a0 a1 a2 a3 d
compute d=1.0
stat(NOPRINT) r1
compute start = 2
compute end = 1943
set v = %variance
set u = 0.0
frml et = r1-b0-b1*v-(b2+b3*v)*r1{1}
frml ht = a0+a1*u{1}**2+a2*v{1}+%if(u{1}<0.0, a3*u{1}**2, 0.0)
***Using GED density
frml Lt = (v(t)=ht(t)), (u(t)=et(t)), $
log(.5)+log(d)+.5*%lngamma(3/d)-1.5*%lngamma(1/d)-.5*log(v)- $
exp((d/2.0)*(%lngamma(3/d)-%lngamma(1/d)))*(abs(u/sqrt(v)))**d
linreg(noprint) r1; # constant r1{1}
compute b0=%beta(1), b1=0.0, b2=%beta(2), b3=0.0
compute a0=%seesq, a1=.09781, a2=.83756, a3=0.0
nlpar(subiter=250)
maximize(method=simplex,recursive,iterations=6) Lt 2 *
maximize(method=bfgs,robust,recursive,iter=500) Lt 2 *
The output is:
MAXIMIZE - Estimation by Simplex
Daily(5) Data From 2006:04:04 To 2014:03:31
Usable Observations 19
Skipped/Missing (from 2085) 2066
Function Value 172.1642
Variable Coeff
1. B0 0.000057147
2. B1 -0.301938042
3. B2 0.014385197
4. B3 -0.055167436
5. A0 0.000193743
6. A1 0.077369570
7. A2 -0.064979929
8. A3 -0.070342733
9. D 0.151616428
MAXIMIZE - Estimation by BFGS
NO CONVERGENCE IN 18 ITERATIONS
LAST CRITERION WAS 0.0000010
Function Value 268.2201
1. B0 0.000057 0.000001 40.36660 0.00000000
2. B1 -0.304113 0.009320 -32.62939 0.00000000
3. B2 0.014385 0.000000 0.00000 0.00000000
4. B3 -0.055167 0.000000 0.00000 0.00000000
5. A0 0.000195 0.000016 11.87531 0.00000000
6. A1 -5514.806599 0.170650 -32316.40693 0.00000000
7. A2 -0.043771 0.025546 -1.71343 0.08663372
8. A3 58066.352495 31.382881 1850.25561 0.00000000
9. D 0.108551 0.038620 2.81076 0.00494253
Many thanks,
Aixia
51 return_xls.xls
(6.77 MiB) Downloaded 1009 times
Re: How to deal with zeros in data?
The strings of zeros aren't directly the problem. The problem is that you're using the GED which (as I pointed out in the earlier post) is a bad choice. Use the t instead if you want to allow for fat tails. You're also using very old codings---both the GED and the t have built-in functions, MAXIMIZE has the PMETHOD and PITERS options so you don't have to do two separate MAXIMIZE instructions and the RECURSIVE option has no effect.
As to what you should do with the zeros, if you have a string of observations where the markets are closed, you probably want those out of the data set. You might want to put in a dummy to indicate the first entry after the markets have been closed and add a variance shift to the GARCH model to allow for higher variance on those observations.
Aixia_Mei
Many thanks for your reply. I've rewritten the two places you pointed out.The updated codes is:
set r1 = PUDONG
stat(NOPRINT) r1
compute start = 2
compute end = 2087
set v = %variance
set u = 0.0
***GJR-GARCH(1,1)
***with t distributed errors
garch(asymmetric,p=1,q=1,distrib=t,regressors,hseries=ht) / r1
# constant v r1{1} v*r1{1}
nlpar(subiter=250)
maximize(pmethod=simplex,piters=15,method=bfgs,iters=500,robust) ht gstart gend *
The above codes is run with a result of an error message, which I cannot understand:
## SX22. Expected Type SERIES[REAL], Got FRML[REAL] Instead
>>>>ressors,hseries=ht)<<<<
Aixia
Because you're trying to use HT in two different ways:
FRML:
SERIES:
Use different names for the different purposes.
Aixia_Mei
TomDoan wrote:Because you're trying to use HT in two different ways:
FRML:
SERIES:
I've rewritten the code of t distribution, but I don't know how to set the value of x in the t density function.
I get an error message from RATS as:
## SX11. Identifier X is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>t)),%TDENSITY(x,nu)<<<<
My codes is as follows:
set r1 = PUDONG
stat(NOPRINT) r1
compute start = 2
compute end = 2087
set v = %variance
set u = 0.0
***GJR-GARCH(1,1)
frml Lt = (v(t)=ht(t)), (u(t)=et(t)),%TDENSITY(x,nu)
nlpar(subiter=250)
maximize(pmethod=simplex,piters=15,method=bfgs,iters=500,robust) Lt gstart gend *
You want the %LOGTDENSITY function, not %TDENSITY. The x and nu in the description of the %TDENSITY (note that they're different for %LOGTDENSITY) are the formal arguments. You have to replace them with the appropriate variables or expressions for the way you are writing this. You don't even have a degrees of freedom variable in your parameter set, so you're not getting too far anyway, but your variance will be v(t) and your "u" will be u(t).
Note that if the message says that "X" is undefined, it means that X is undefined, so either have a mistake and didn't want to say "X" or you forgot to define X.
Aixia_Mei
TomDoan wrote:You want the %LOGTDENSITY function, not %TDENSITY. The x and nu in the description of the %TDENSITY (note that they're different for %LOGTDENSITY) are the formal arguments. You have to replace them with the appropriate variables or expressions for the way you are writing this. You don't even have a degrees of freedom variable in your parameter set, so you're not getting too far anyway, but your variance will be v(t) and your "u" will be u(t).
Many thanks Tom. But are there any examples in either the free manuals or the materials of the GARCH volatility course have mentioned how to do this? I didn't find by myself.
There are quite a few that use %LOGDENSITY (for a Normal). For instance, GARCH7_1.RPF in the course:
frml logl = u=sp-meanf,uu=u^2,h=hf,%logdensity(h,u)
For the same model with a t, you add the degrees of freedom to the parameter set (NU is the obvious name), initialize it (NU=10 probably will work fine) and replace the %logdensity(h,u) with %logtdensity(h,u,nu) (with h and u being whatever you are calling your variance and residual).
Aixia_Mei
TomDoan wrote:There are quite a few that use %LOGDENSITY (for a Normal). For instance, GARCH7_1.RPF in the course:
Thanks a lot Tom. By following your instructions, I finally get the result. But both the coefficient and standard of b3 seem strange. The values are too big to be correct. Besides, when I tried to run my codes with only the first half of the first stock's time series data, there is even no converge. However, when I tired with other time series data of the second stock, which have much lesser zeros, it converges. Can you give me some suggestions? I don't really know what can I do to solve this problem.
My current codes are as follows:
DATA(FORMAT=XLS,ORG=COLUMNS,RIGHT=2) 2006:04:03 2010:03:30 PUDONG
set r1 = PUDONG
nonlin b0 b1 b2 b3 a0 a1 a2 a3 nu
compute nu=10.0
stat(NOPRINT) r1
compute start = 2
compute end = 1043
set v = %variance
set u = 0.0
***GJR-GARCH(1,1)
frml Lt = (v(t)=ht(t)), (u(t)=et(t)),%LOGTDENSITY(v,u,nu)
nlpar(subiter=250)
maximize(pmethod=simplex,piters=15,method=bfgs,iters=500,robust) Lt 2 *
The results with two different time range:
Convergence in 28 Iterations. Final criterion was 0.0000061 <= 0.0000100
Usable Observations 2085
Function Value 5012.9736
1. B0 -0.00098677 0.00050287 -1.96227 0.04973082
2. B1 0.99633406 0.73397511 1.35745 0.17463847
3. B2 -0.02106737 0.02713513 -0.77639 0.43752027
4. B3 -3.45171694 19.76990309 -0.17459 0.86139825
5. A0 0.00000194 0.00000203 0.95537 0.33939265
6. A1 0.07091891 0.03167404 2.23902 0.02515440
7. A2 0.94568887 0.01941585 48.70707 0.00000000
8. A3 0.01062862 0.02529564 0.42018 0.67435686
9. NU 3.04404519 0.43005143 7.07833 0.00000000
NO CONVERGENCE IN 36 ITERATIONS
LAST CRITERION WAS 0.0000000
Daily(5) Data From 2006:04:04 To 2010:03:30
Usable Observations 1041
Function Value 2195.8753
1. B0 0.000008 0.000022 0.38762 0.69830055
2. B1 0.351136 0.557324 0.63004 0.52866853
3. B2 0.051197 0.026988 1.89705 0.05782105
4. B3 2.316022 12.489829 0.18543 0.85288970
5. A0 0.000000 0.000000 0.19918 0.84211948
6. A1 0.860045 0.228412 3.76533 0.00016633
7. A2 0.588121 0.087199 6.74456 0.00000000
8. A3 2.076042 0.597498 3.47456 0.00051169
9. NU 2.291973 0.178240 12.85893 0.00000000
Aixia
It's your model. Is that interaction term (the B3) your idea? In B3*V*R1{1}, the B3*V needs to be no more than O(1) or the model will go unstable. Thus, if you change the scale of the data, or run over a range with higher volatility, the B3 will have to adapt. Unlike B2, there is no natural scale for it. To be perfectly honest, I would be shocked if B3 came in statistically significant.
I'd be concerned with the fact that you're getting NU's that close to 2. Those are really, really fat tails, which would make me think that there are either some serious outliers or a structural break in the model.
Aixia_Mei
TomDoan wrote:It's your model. Is that interaction term (the B3) your idea? In B3*V*R1{1}, the B3*V needs to be no more than O(1) or the model will go unstable. Thus, if you change the scale of the data, or run over a range with higher volatility, the B3 will have to adapt. Unlike B2, there is no natural scale for it. To be perfectly honest, I would be shocked if B3 came in statistically significant.
The baseline model I currently adopt is actually a very popular and classic model of feedback trading behavior, the heterogeneous trader model (Sentana and Wadhwani, 1992). I've used my codes (both GJR-GARCH with GED and t) to run data from other countries' markets, all results seem good. So I started to compare the data set of Chinese market and data from other markets, then noticed the significant difference is that quite a lot of zeros are in China's data. So think may be that's the problem.
What I just did is deleting all the zeros in my database but keep the column of date unchanged, just to see whether I can get proper results with a zero-free data set. It seems you are correct, the results still look strange, some of them have no convergence, some have very weird coefficient values. I'll discuss this with my supervisors and may return to you again.
Thanks a lot for your time and suggestions.
Aixia_Mei
To solve those strings of zeros in my time series data, I decide to introduce a deterministic, time varying variable Nt to my GARCH variance equation. Nt here represents the length of non-trading period: the number of the non-trading days between the current trading day t to the preceding trading day t-1.
I get some questions to write the code of Nt. For this variable, we have firstly to make sure the condition of Rt<>0, Rt-1==0 is met. And then the number of the continuous zeros in the log return of the time series will be calculated and displayed. My question is how to write the code of Nt? How to ask RATS to calculate the number of a string of zeros for a specific time point?
Perhaps something like below:
If r{1}==0 and r<>0,
set nt =
else
set nt = 0
Many thanks,
Aixia
See the description of the %IF function in the Introduction to RATS book.
Aixia_Mei
TomDoan wrote:See the description of the %IF function in the Introduction to RATS book.
Thanks for that. But for the function %if(x,y,z), the condition of my case is not about whether the value of x is equal to 0 or not. So I don't know whether my idea can be written as:
set nt = %if(r{1}==0 r<>0,y,0)
Also, my original question is actually "How to ask RATS to calculate the total number of the non-trading days? In other words, how to ask RATS to calculate the number of a string of continuous zeros?" Which means how to write the code of y in the above code?
Kind regards,
Aixia
The following will give you a count of consecutive zeroes in the series x:
set(first=(x==0.0)) zerocount = %if(x==0,zerocount{1}+1,0.0)
