Filardo_msvartvpemestima, missing value
vtsa
When I run the Filardo (1994) code with my data, I got the following message:
equation p1eq *
# constant oil_net{1}
equation p2eq *
compute v1=log(.5/.3)~~0.0
compute v2=log(.95/.05)~~0.0
compute mu(1)=-0.05,mu(2)=.006
@MSVARTVPEMEstimate(cvcrit=.0001) gstart gend
The Error Occurred At Location 949, Line 41 of MSVARTVPEMESTIMA
There is no missing value in the oil_net data, but it has zeros and some positive values. However, when I do the following change, I got the same message:
sample(smpl=%valid(oil_net)) oil_net / oilnet
calendar(irregular)
compute gstart=1,gend=%nobs
* Define the logistic index for the transitions
equation p1eq *
equation p2eq *
Could you please help me to solve this problem?
I appreciate You very much for your help!
vasif
equation p1eq *
equation p2eq *
calendar(irregular)
equation p1eq *
equation p2eq *
vasif
Re: Filardo_msvartvpemestima, missing value
That may (and probably does) have nothing to do with the transition. You could have a problem with the overall range of the MS estimation. Have you successfully estimated the same model with fixed transition probabilities?
vtsa
When I estimated the model with the MSRegression option (which is shown below) , I got the following absurd result:
This result is not satisfying. The conditional means both are negative and P(1,2) is insignificant.
Further, I estimated it with MSVAR option (which is shown below) and I got the following result with no convergence:
Does that mean that the problem is in the oil_net data? I try to replicate Reymond and Rich(1997)'s "Oil and The Macroeconomy:A Markov Swithcing Approach" which uses net real oil price increase (oil_net) as a leading indicator of the GDP.
I appreciate you very much for your help.
@MSRegression(switch=c,nfix=2,states=2) gip
# constant gip{1 2} oil_net{1 2}
nonlin(parmset=regparms) betas gammas sigsq
nonlin(parmset=msparms) p
MAXIMIZE - Estimation by BFGS
Convergence in 15 Iterations. Final criterion was 0.0000041 <= 0.0000100
Monthly Data From 1986:05 To 2014:09
Usable Observations 341
Function Value 601.4103
1. BETAS(1)(1) -0.269164274 0.101183049 -2.66017 0.00781008
2. BETAS(1)(2) 0.212097718 0.131018909 1.61883 0.10548323
3. BETAS(1)(3) 0.056780364 0.127282691 0.44610 0.65552754
4. BETAS(2)(1) -0.119412812 0.086367741 -1.38261 0.16678480
5. BETAS(2)(2) -0.187672498 0.086068541 -2.18050 0.02922038
6. BETAS(2)(3) -0.023092730 0.074578201 -0.30964 0.75683130
7. GAMMAS(1) 0.007140545 0.002331930 3.06207 0.00219809
8. GAMMAS(2) -0.692517267 0.054594860 -12.68466 0.00000000
9. SIGSQ 0.001675879 0.000131322 12.76162 0.00000000
10. P(1,1) 0.932616990 0.086117193 10.82963 0.00000000
11. P(1,2) 0.054442146 0.075560269 0.72051 0.47120928
Conditional Mean for Regime 1 -0.36815
Conditional Mean for Regime 2 -0.09863
@msvarsetup(lags=2,switch=m)
# gip oil_net
nonlin(parmset=varparms) mu phi sigma
NO CONVERGENCE IN 13 ITERATIONS
LAST CRITERION WAS 0.0000000
Function Value NA
1. MU(1)(1) 0.002697 328.997335 8.19657e-006 0.99999346
2. MU(1)(2) -0.101547 4369.504653 -2.32399e-005 0.99998146
3. MU(2)(1) 0.003668 0.001139 3.21906 0.00128612
4. MU(2)(2) 0.011318 0.002412 4.69278 0.00000270
5. PHI(1)(1,1) -0.675947 0.035885 -18.83668 0.00000000
6. PHI(1)(2,1) -0.114823 0.032018 -3.58624 0.00033548
7. PHI(1)(1,2) -0.061099 0.034179 -1.78762 0.07383761
8. PHI(1)(2,2) 0.246516 0.019488 12.64997 0.00000000
9. PHI(2)(1,1) -0.179852 0.040657 -4.42369 0.00000970
10. PHI(2)(2,1) -0.048140 0.029950 -1.60736 0.10797612
11. PHI(2)(1,2) 0.011046 0.041982 0.26312 0.79245564
12. PHI(2)(2,2) -0.004283 0.059396 -0.07211 0.94251275
13. SIGMA(1,1) 0.001759 0.000105 16.75340 0.00000000
14. SIGMA(2,1) 0.000001 0.000076 0.00683 0.99454680
15. SIGMA(2,2) 0.001319 0.000123 10.76753 0.00000000
16. P(1,1) 0.851520 33738.732131 2.52387e-005 0.99997986
17. P(1,2) -0.000010 0.000036 -0.27586 0.78265851
AIC = NA SIC = NA LogL = NAI appreciate you very much for your help.
1. Why would you do NFIX=2? That fixes the intercept and the gip{1} across the two regimes. I can't imagine that's what you want.vasifabiyev wrote:Dear Tom,
2. How do you compute the conditional means? This isn't a self-contained process, so there is no way to compute the conditional mean based upon one equation in isolation.
vtsa
Dear Tom Doan,
I just meant to make the oil_net variable to be independent of the unobserved state, but I understand that I'm wrong. Calculation of conditional means also wrong. Conditional means are estimated by using MSVARsetup. And the problem is sourced from the oil_net data, isn't it.
I’m trying to estimate the following model.
[y(t)-μ(s)(t)] = ∑α(i)[y(t-i) - μ(s)(t-i)] + ∑β[oil(t-i)]
In that model the oil variable is assumed to be independent of the unobserved state variable (St).
I estimated it by using MSVARsetup and got the following result.
But MSVARsetup also takes the oil variable as an endogenous variable. Should I take the coefficients of the above mentioned equation for interpretation and ignore the coefficients of the second oil equation? Am I right or how should I do?
I appreciate You very much for your help. I look forward to hearing from You.
# gip oil
Convergence in 27 Iterations. Final criterion was 0.0000037 <= 0.0000100
Function Value 952.4569
1. MU(1)(1) -0.029939675 0.007697336 -3.88962 0.00010040
2. MU(1)(2) -0.209409850 0.029040433 -7.21098 0.00000000
3. MU(2)(1) 0.005133601 0.001239563 4.14146 0.00003451
4. MU(2)(2) 0.011578332 0.005323196 2.17507 0.02962474
5. PHI(1)(1,1) -0.724461603 0.043088783 -16.81323 0.00000000
6. PHI(1)(2,1) -0.108610053 0.109616466 -0.99082 0.32177408
7. PHI(1)(1,2) -0.028157007 0.025979778 -1.08380 0.27845137
8. PHI(1)(2,2) 0.225297042 0.056265852 4.00415 0.00006224
9. PHI(2)(1,1) -0.220512666 0.045502149 -4.84620 0.00000126
10. PHI(2)(2,1) -0.025448829 0.110172017 -0.23099 0.81732120
11. PHI(2)(1,2) 0.029158569 0.027153989 1.07382 0.28290216
12. PHI(2)(2,2) -0.079548526 0.059973685 -1.32639 0.18471038
13. SIGMA(1,1) 0.001629466 0.000102651 15.87382 0.00000000
14. SIGMA(2,1) 0.000044226 0.000184693 0.23946 0.81075121
15. SIGMA(2,2) 0.006491502 0.000536201 12.10648 0.00000000
16. P(1,1) 0.530962384 0.128476636 4.13275 0.00003584
17. P(1,2) 0.020376396 0.008905340 2.28811 0.02213112
That model can't be estimated directly by any of the higher end procedures because you're adding the exogenous variable to the MS-autoregression. However, I'm not sure it's a good form. Precisely because of the exogenous variable, the "Hamilton" style mean switching isn't appropriate, since the mean of the process is time-varying with the exogenous variables. It would make more sense to have a model with the constant switching rather than the mean. You can set that up withvasifabiyev wrote:Dear Tom Doan,
@MSRegression(switch=c,nfix=4,states=2) gip
# gip{1 2} oil_net{1 2} constant
Note that you list the fixed parameters first---in your previous attempt, you had the fixed parameters listed last.
vtsa
Re: Filardo_msregtvpemestima
I estimated a TVTP-MS model with non-switching variance by using @MSregression option:
I got the following results:
The standard error and the t-statistic of sigsq are both zero. How to solve this problem?
I appreciate You for your help!
( Note: MSregression code is obtainded from https://estima.com/forum/viewtopic.php? ... t=30#p5340)
# oilrd{1 to 2} gip{1 to 2} constant
compute gstart=1986:2,gend=2014:9
@MSRegInitial gstart gend
@MSFilterSetup(em)
nonlin(parmset=common) betas gammas sigsq
dec equation p1eq p2eq
dec vector v1 v2
dec vector p1mean p2mean
nonlin(parmset=tv) v1 v2
MAXIMIZE - Estimation by BHHH
Convergence in 37 Iterations. Final criterion was 0.0000069<= 0.0000100
Monthly Data From 1986:02 To 2014:09
Usable Observations 344
Function Value 622.1343
Variable CoeffStd Error T-Stat Signif
1. V1(1) -3.29514816 4.08188937 -0.80726 0.41951640
2. V1(2) 31.11261285 41.79693227 0.74438 0.45664933
3. V2(1) 3.20327196 0.43964593 7.28603 0.00000000
4. V2(2) 3.37291935 4.26251194 0.79130 0.42876982
5. BETAS(1)(1) -0.08888280 0.00998915 -8.89794 0.00000000
6. BETAS(2)(1) 0.01270169 0.00221624 5.73119 0.00000001
7. GAMMAS(1) 0.01929429 0.01894784 1.01828 0.30854278
8. GAMMAS(2) 0.04108859 0.02264377 1.81457 0.06959075
9. GAMMAS(3) -0.73948948 0.04217017 -17.53584 0.00000000
10. GAMMAS(4) -0.23550132 0.05550672 -4.24275 0.00002208
11. SIGSQ 0.00124526 0.00000000 0.00000 0.00000000I appreciate You for your help!
What you're copying has regime-switching variances, so you'll have to switch the calculation to use the fixed variance instead.
