I am trying to run mGARCH models for log-return oil prices & H index. (bi-variate) :
So I run this code in RATS 8.0 :
open data Y1_O_A.xls
data(format=xls,org=columns) / O A
compute gstart=2,gend=2000
garch(p=1,q=1,mv=CC,variance=varma,pmethod=simplex,piters=5,hmatrices=hh, rvectors=rv) gstart gend O A
MV-GARCH, CC with VARMA Variances - Estimation by BFGS
Log Likelihood 12223.0018
1. Mean(1) 3.3466e-004 4.0690e-004 0.82246 0.41081547
2. Mean(2) 6.4086e-004 2.7855e-004 2.30071 0.02140775
3. C(1) 3.6206e-006 1.6079e-006 2.25172 0.02434008
4. C(2) -1.9890e-008 4.4641e-007 -0.04455 0.96446242
5. A(1,1) 0.0522 8.9554e-003 5.83329 0.00000001
6. A(1,2) -6.3090e-003 0.0113 -0.55932 0.57594292
7. A(2,1) -9.6068e-003 6.7144e-003 -1.43077 0.15249594
8. A(2,2) 0.0520 9.7580e-003 5.32894 0.00000010
9. B(1,1) 0.9312 0.0141 66.11622 0.00000000
10. B(1,2) 0.0969 0.0710 1.36506 0.17223538
11. B(2,1) 0.0952 0.0439 2.16951 0.03004371
12. B(2,2) 0.9355 0.0119 78.88939 0.00000000
13. R(2,1) 0.1271 0.0204 6.22132 0.00000000
1. the parameters are a little bit different from the original paper:
Here I have A , B matrices which I assume are alpha & betas in table 4 of paper. (then how can calculate alpha+beta ? is it A(1,1)+B(1,1) and A(2,2)+B(2,2) ??
2.Then what is R(2,1) ?
3.is Mean (1) the same as AR ?
4.is mean (2) the same as MA?
thanks in advance.
