Rolling-VAR-MGARCH-M
Re: Rolling-VAR-MGARCH-M
You mean the diagnostics? @MVQSTAT and practically any other testing instruction/procedure in RATS will produce the %CDSTAT and %SIGNIF variables which give the test statistic and significance level. You just need to save what you want into elements of a series.
hasanov
Unread post by hasanov »
I would like to include "test" instruction in each window and save the results in a separate object.
For example,
test(zeros,title="No GARCH aij=bij=dij=0")
# 26 27 28 29 30 31 32 33
The above command should be repeated for each window and saved when iterations are completed.
Any guidance is much appreciated.
Thank you
TEST also produces %CDSTAT and %SIGNIF, so you can save those just like you do the diagnostics---just make sure you save each immediately after it's calculated.
hasanov
It looks we can include ONLY one "test" instruction:
For example, we can't conduct the following two tests in the same iterations.
test1:
test(zeros, title="No GARCH aij=bij=0")
# 23 24 25 24
and
test2:
test(zeros, title="Diagonal VAR in the mean")
# 3 13 5 15 7
I feel if I include second test which perhaps overwrites the first one.
Nevertheless, %CDSTAT and %SIGNIF are working fine if I use them only once.
Regards
Just use different series for the results of each test. Save the results of the first test before going on to the second.
hasanov
As far as I know, so far "distrib" has three options (i.e., norm, t, and GED) for most of MGARCH models in RATS. Has there been any development in this area? Now multivariate skew t is becoming more popular in the literature. Will that be available to estimate MGARCH models in RATS?
Thank you
We've had the Bauwens-Laurent example for at least seven years.
hasanov
Thank you for your info.
Would that be possible to incorporate multivariate skew t in the estimations within the loop?
Sure. Have you looked at the newer version of the program? It just uses a GARCH instruction with slightly different options. Whether doing that with a rolling window is a good idea is a completely different question.
hasanov
In the code below, I would like to estimate MGARCH-M-skew t model through the expanding windows.
However, RATS keeps generating the following error message.
## SX4. Expected Blank or Tab Here
>>>>2<<<<
I would be appreciated if you could help me on this issue.
Regards
OPEN DATA "Data.txt"
CALENDAR(D) 2008:3:25
DATA(FORMAT=PRN,ORG=COLUMNS,DATEFORM="d/m/y") 2008:03:25 2019:07:31 Date var1 var2 var3
set rvar1 = 100.0*(log(var1)-log(var1{1}))
set rvar2 = 100.0*(log(var2)-log(var2{1}))
set rvar3 = 100.0*(log(var3)-log(var3{1}))
source logmvskewt.src
dec vect[series] sqrth(3)
dec vect[series] eps(3)
dec symm[series] hhs(3,3)
clear(zeros) hhs
compute n=3
dec vector logxi(n)
nonlin(parmset=skewparms) nu logxi
compute logxi=%zeros(n,1)
compute nu=10.0
function logmvskewtfnc h u
type real logmvskewtfnc
type symm h
type vect u
compute logmvskewtfnc=$
%logmvskewt(inv(%decomp(h))*u,%exp(logxi),nu)-.5*%logdetxx(h)
do regend = 2013:12:25, 2019:07:31, 5
equation var1_eq rvar1
# constant sqrth(1) sqrth(2) sqrth(3) rvar1{1} rvar2{1} rvar3{1}
equation rvar2_eq rvar2
equation rvar3_eq rvar3
group varmah var1_eq rvar2_eq rvar3_eq
clear(zeros) sqrth eps
do iters=1,3
   estimate(model=varmah,resids=resids)
   set eps(1) %regstart() * = resids(1)
   set eps(2) %regstart() * = resids(2)
   set eps(3) %regstart() * = resids(3)
end do iters
compute cv0=%sigma
garch(model=varmah, mv=bekk, asymmetric, robust, rvectors=rv, hmatrices=hh, mvhseries=hhs, pmethod=simplex, piters=15, cvcrit=0.0001, iters=1000, stdresids=zu,$
parmset=skewparms, density=logmvskewtfnc, uadjust=%pt(eps,t,rv(t)),hadjust=%(sqrth(1)=sqrt(hhs(1,1)), sqrth(2)=sqrt(hhs(2,2)), sqrth(3)=sqrt(hhs(3,3))))$
2008:03:25 regend rvar1 rvar2 rvar3
compute loglskew=%logl
end do regend
Add a space between the )))) and $ on this:
hasanov
Thank you very much !! It is fine now.
Just want you to clarify one more stuff.
The chunk of code for skew t given below: should it be within or out of the loop (i.e., "do regend = 2013:12:25, 2019:07:31, 5 .... end do regend" ). In the current code, I placed it before starting the loop. Would that be fine?
dec vector logxi(n)
compute nu=10.0
type symm h
type vect u
It has to be outside.
hasanov
As you mentioned in one of your posts:
@mvqstat(lags=5)
# zu
TomDoan wrote: ...@MVQSTAT applied to the jointly standardized residuals...
How to apply this procedure to the squared standardized residuals? Following arrangement definitely does not work because zu is a vector of standardized residuals.
@mvqstat(lags=5)
# zu^2
Thank you
You don't. You use @MVARCHTEST applied to the standardized residuals (which handles the cross products). Multivariate GARCH diagnostics are described in the User's Guide.
