- to estimate VARMA-MGARCH-in-mean model through the rolling windows where the fixed window size is 1250 and increment is 5.
- to generate 5-step ahead volatility forecasts in each window and save these series in hhat11 and hhat22 objects.
- this code also saves some of estimated coefficients from each regression in coef1, coef2, and coef3 objects.
I would be appreciated if anyone could check the code whether everything is OK. I suspect the mean model (i.e., VARMA) and var-cov model (i.e., MGARCH-M) use different sample periods.
Attached is the code file.
Many thanks
set rvar1 = 100.0*(log(var1)-log(var1{1}))
set rvar2 = 100.0*(log(var2)-log(var2{1}))
set rvar3 = 100.0*(log(var3)-log(var3{1}))
source mvgarchfore.src
compute d=1250
dec series hhat11
dec series hhat22
dec series hhat33
dec series hhat12
dec series hhat13
dec series hhat23
clear hhat11
clear hhat22
clear hhat33
clear hhat12
clear hhat13
clear hhat23
clear coef1 coef2 coef3 coef4 coef5
clear tstat1 tstat2 tstat3 tstat4 tstat5
clear conv iter
dec vect[series] sqrth(3)
dec vect[series] eps(3)
dec symm[series] hhs(3,3)
clear(zeros) hhs
do regend = 2013:01:09, 2019:05:31, 5
equation oil_eq rvar1
# constant sqrth(1) sqrth(2) sqrth(3) rvar1{1} rvar2{1} rvar3{1}
equation rvar2_eq rvar2
equation rvar3_eq rvar3
group varmah oil_eq rvar2_eq rvar3_eq
clear(zeros) sqrth eps
do iters=1,3
estimate(model=varmah,resids=resids)
set eps(1) %regstart() * = resids(1)
set eps(2) %regstart() * = resids(2)
set eps(3) %regstart() * = resids(3)
end do iters
compute cv0=%sigma
garch(model=varmah, mv=bekk, robust, distrib=norm, rvectors=rv, hmatrices=hh, mvhseries=hhs, pmethod=simplex, piters=15, cvcrit=0.0001, iters=1000, presample=cv0,$
uadjust=%pt(eps,t,rv(t)),hadjust=%(sqrth(1)=sqrt(hhs(1,1)), sqrth(2)=sqrt(hhs(2,2)), sqrth(3)=sqrt(hhs(3,3)))) regend-d+1 regend rvar1 rvar2 rvar3
@MVGarchFore(MV=BEKK, steps=5) hh rv
do i=1,5
compute hhat11(regend+i) = hh(regend+i)(1,1)
compute hhat22(regend+i) = hh(regend+i)(2,2)
compute hhat33(regend+i) = hh(regend+i)(3,3)
compute coef1(regend) = %beta(9)
compute coef2(regend) = %beta(10)
compute coef3(regend) = %beta(11)
compute coef4(regend) = %beta(38)
compute coef5(regend) = %beta(44)
compute tstat1(regend) = %tstats(9)
compute tstat2(regend) = %tstats(10)
compute tstat3(regend) = %tstats(11)
compute tstat4(regend) = %tstats(38)
compute tstat5(regend) = %tstats(44)
compute conv(regend) = %converged
compute iter(regend) = %ITERS
end do regend
print / coef1 tstat1 coef2 tstat2 coef3 tstat3
print / coef4 tstat4 coef5 tstat5
print / hhat11 hhat22 hhat33
print / conv iter
