VAR-GARCH-M
economics2012
Re: VAR-GARCH-M
Oops, that is what I meant.
Thanks a lot.
Thanks a lot.
economics2012
Re: VAR-GARCH-M
I do have two questions about Elder's specialized version of the VAR-GARCH-M procedure:
The first question is about computing garchp(i) below. Can you please explain to me why garchp(i) is computed as ( compute garchp(i)=||%sigma(i,i)/5.0,.20,.60|| ), why dividing by 5.0, .20,.60?
dec vect[equation] garchmeqns(%nvar)
dec vect[vect] bvec(%nvar)
dec vect[vect] garchp(%nvar)
do i=1,%nvar
compute garchmeqns(i)=%modeleqn(basevar,i)
compute bvec(i)=%eqncoeffs(garchmeqns(i))
My second question is about :
compute b=0.0
function %%garchinit
compute bb=||1.0,0.0|b,1.0||
gset hh 1 gstart-1 = ||garchp(1)(1)/(1-garchp(1)(2)-garchp(1)(3))|0.0,garchp(2)(1)/(1-garchp(2)(2)-garchp(2)(3))||
gset uu 1 gstart-1 = hh(t)
I don't understand this line:
Thanks a lot for all your help.
do i=1,%nvar
compute b=0.0
Re: VAR-GARCH-M
Neither of those are "computed". Those are simply guess (or pre-sample) values. The equilibrium variance for a univariate GARCH model with c+a h(t-1) + b u(t-1)^2 is c/(1-a-b). The first would be clearer if it were written equivalently as
compute garchp(i)=||%sigma(i,i)*(1-.20-.60),.20,.60||
as it is solving out for c using the observed variance in place of the (unobservable) equilibrium variance and the guess values for a and b.
The second is just directly using the c/(1-a-b) formula to compute the equilibrium variances for the pre-sample.
economics2012
Re: VAR-GARCH-M
That makes sense. Thanks a lot.
And why "1 gstart-1" are included below next to gset hh? Also, why 0.0 is added to the matrix?
Thanks a lot
Thanks a lot
Re: VAR-GARCH-M
Those are for pre-sample values. Everything from gstart on will be set as part of the estimation process. The 0 is the 1,2 element, which is supposed to be zero since the rotation is supposed to make the residuals uncorrelated.
economics2012
Re: VAR-GARCH-M
Thanks a lot.
Now I am trying to run the procedure for GARCH(2,2) as attached in the file below. Does it look right? By the end of the code:
frml garchmlogl = hh=%%garchh(t),sqrthoil=sqrt(hh(t)(1,1)),$
ux=bb*yvec(t)-%%garchmu(t),uu=%outerxx(ux),%logdensity(hh,ux)
is sqrt(hh(t)(1,1)) considered right?
Many Thanks,
Many Thanks,
Re: VAR-GARCH-M
The (1,1) is the position in the covariance matrix (thus variance of variable 1, i.e. oil), so it always stays the same.
economics2012
Re: VAR-GARCH-M
Thanks a lot.
Is the code correct as a GARCH (2,2)?
economics2012
Re: VAR-GARCH-M
When we tested for garch effect, the procedure we used is before garch-in-mean, correct? So, the attached file shows the existence of garch effect in the basic VAR model before using garch-in-mean model. Am I correct?
Many Thanks
Many Thanks
Last edited by economics2012 on Tue May 29, 2012 10:45 pm, edited 1 time in total.
Re: VAR-GARCH-M
Your GARCH test is on the standardized residuals from the GARCH-M. And a .04 significance level on that with 6000 data points is quite good---you'll almost never get a value better than that with actual data.
economics2012
Re: VAR-GARCH-M
Thanks a lot, Tom.
The results are sensitive to the number of lags I use. For instance, using 42 lags, the results are positive and significant. However when using 35 lags the results are not significant (i.e. uncertainty in oil price has no effect on stock returns).
I am trying to get the optimal number of lags using daily data. I am using the following procedure but I am getting errors. Can you please help me adjusting this procedure?
Re: VAR-GARCH-M
That's a really bad idea. You have plenty of data to estimate either a 35 or 42 lag model. If the residuals pass a whiteness test (at either lag), just go with what you have. However, the job of the econometrician isn't (or at least shouldn't be) to monkey with specifications until getting the result that he wants. All indications are that this elusive parameter just really isn't well-estimated. When you have 6000 data points, it's very easy for parameters to appear significant at conventional significance levels when they are really just statistical artifacts that disappear with slight changes in specification. I would suggest that you read Chapter 4 of Leamer's Specification Searches (Wiley, 1978).
economics2012
Re: VAR-GARCH-M
Thanks a lot Tom for your advice. I am reading chapter 4.
I just wanted to check for the lag length in the VAR using AIC/BIC criterion.
now I need to check for daily effect by adding days of the week dummies to the mean equation and the variance equation.
Can you please help in writing the code in rats?
Many thanks for all your help.
economics2012
Re: VAR-GARCH-M
I believe for the mean equation that is how I add the dummy variables for the days of the week (Mondays through Thursdays):
system(model=basevar)
variables oilgrow stockreturns
lags 1 to nlags
det constant sqrthoil monday tuesday wednesday thursday
Am I correct?
I am not sure how to add the dummies to the variance equation!
lags 1 to nlags
Am I correct?
