garchmvbootstrap.rpf
ac_1
Re: garchmvbootstrap.rpf
Unread post by ac_1 »
Please can you fix - the procedure does not run correctly.
ac_1
I'll presume for whatever reasons the new code cannot be adapted into a procedure.
Also, whilst Wald test using QMLE adjustment or maybe Wald with HAC adjustment (will they be almost identical?), should be able to help to judge multi-step VaR forecasts using overlapping returns, I am not certain they are the answer.
IMHO Block Bootstrapping Kupiec (ideally as a procedure) is a much better solution for financial returns:
https://estima.com/RATSBetaHelp/topics/ ... pping.html
https://estima.com/RATSBetaHelp/topics/ ... aprpf.html
ac_1
Here's an attempt at Block Bootstrap Kupiec, as a minimal procedure.
There is a small difference (4th decimal place...) in the results for
%%pofbootse from the STATS instruction i.e. all the ndraws of the POF's stored as a vector
vs.
the Alternative acsum method, not sure why that would be?
Please can you see if the procedure is correct/incorrect.
procedure acKupiecBlockBoot trigger start end
   type series    trigger
   type integer   start end
   local integer           startl endl draw
   local integer           Nobs kobs kboot
   local integer           blocklen
   local real              violratio alphahat alphahatboot
   local real              pofobs pofboot countextreme
   local series[integer]   bootentries
   local series            H0DIST bootviol
   local real              acsum acsum_SS res_S_M res_S_MSS res_S_SE
   option real    alpha       .01
   option real    siglevel    .05
   option integer ndraws      10000
   option integer horizon     1
   local series   temp gPOFBoot fPOFBoot
   local series   pofbootdist
   inquire(reglist) startl<<start endl<<end
   # trigger
* --- Set block length ---
   compute blocklen = horizon
* --- Calculate observed statistics ---
   sstats(mean) startl endl trigger>>alphahat
   compute Nobs = %nobs
   compute kobs = fix(alphahat*Nobs)
   compute violratio = alphahat
* --- Observed POF statistic ---
   if (kobs>0.and.kobs<Nobs)
      compute pofobs=2*Nobs*((1-alphahat)*log((1-alphahat)/(1-alpha))+alphahat*log(alphahat/alpha))
   else if (kobs==0)
      compute pofobs=-2*Nobs*log(1-alpha)
   else
      compute pofobs=-2*Nobs*log(alpha)
* --- BLOCK-BOOTSTRAPPING ---
*  --- Calculate p-value ---
   compute countextreme = 0.0
   compute acsum = 0.0
   compute acsum_SS = 0.0
* --- Block Bootstrap series ---
   set pofbootdist 1 ndraws = 0.0
* --- Block Bootstrap loop ---
   do draw=1,ndraws
*     STEP 1: Generate fresh H0DIST for this replication
      set H0DIST startl endl = %if(%ranflip(alpha),1.0,0.0)
*     STEP 2: Resample H0DIST in blocks to create serial dependence
      BOOT(block=blocklen) bootentries startl endl startl endl
      set bootviol startl endl = H0DIST(bootentries(t))
*     STEP 3: Calculate bootstrap POF statistic
      sstats(mean) startl endl bootviol>>alphahatboot
      compute kboot = fix(alphahatboot*Nobs)
      if (kboot>0.and.kboot<Nobs)
         compute pofboot=2*Nobs*((1-alphahatboot)*log((1-alphahatboot)/(1-alpha))+alphahatboot*log(alphahatboot/alpha))
      else if (kboot==0)
         compute pofboot=-2*Nobs*log(1-alpha)
      else
         compute pofboot=-2*Nobs*log(alpha)
*     Store pof bootstrap to a vector pofbootdist for POF statistics and density plot
      compute pofbootdist(draw) = pofboot
*     STEP 4: Count if bootstrap statistic > observed
      if (pofboot>pofobs)
         compute countextreme = countextreme + 1.0
*     Alternatively
      compute acsum = acsum+pofboot
      compute acsum_SS = acsum_SS+(pofboot)^2
   end do draw
* --- Store results ---
   compute %%pofboot = countextreme/ndraws
* https://estima.com/RATSBetaHelp/topics/grangerbootstraprpf.html
* Compute the percentiles of the test statistics
   stats(fractiles) pofbootdist 1 ndraws
   compute %%pofbootmean = %mean
   compute %%pofbootse = sqrt(%variance)
* CONFIRMATION
* Figure out the bootstrapped p-value (SAME AS %%pofboot)
   sstats(mean) 1 ndraws (pofbootdist>pofobs)>>pvalue
   disp "Bootstrapped p-value" pvalue
* Alternatively
   compute res_S_M = acsum/ndraws
   compute res_S_MSS = acsum_SS/ndraws
   compute res_S_SE = sqrt(res_S_MSS-(res_S_M)^2)
   disp 'res_S_M' res_S_M
   disp 'res_S_SE' res_S_SE
* --- Plot density function for pofbootdist ---
*  convert VECTOR to a SERIES for plotting
   set temp 1 ndraws = pofbootdist(t)
   density(smoothing=2.0) temp 1 ndraws gpofboot fpofboot
   * 10 horizons, 10 colours
   compute col = %if(horizon==1,2,$
                     %if(horizon==2,4,$
                     %if(horizon==3,5,$
                     %if(horizon==4,6,$
                     %if(horizon==5,7,$
                     %if(horizon==6,8,$
                     %if(horizon==7,9,$
                     %if(horizon==8,10,$
                     %if(horizon==9,11,12)))))))))
   spgraph(hea="",vfi=1,hfi=1)
   scatter(key=upright,head="A non-parametric empirical approximation to the sampling distribution\\of the POF statistic under H0 with serial dependence",$
            footer="horizon="+%strval(horizon,"#")+",   "+$
                   "POF mean under H0 (bootstrap):"+%strval(%%pofbootmean,".####")+",   "+$
                   "p-value (bootstrap):"+%strval(%%pofboot,".####"),$
            hgrid=||%%pofbootmean||,style=line) 1
   # gpofboot fpofboot 1 ndraws col
* --- Output Results ---
   display "======================================="
   display "--- Block Bootstrap Kupiec POF Test ---"
   display "From "+%datelabel(startl)+" to "+%datelabel(endl)
   display "Horizon (h):" horizon
   display "Block length:" blocklen
   display
   display "--- Sample Statistics ---"
   display "Sample size (N):" Nobs
   display "Observed exceedances (k):" kobs
   display "Violation ratio (k/N):" violratio
   display "Target alpha:" alpha
   display
   display "--- Test Configuration ---"
   display "Significance level:" siglevel
   display "Bootstrap replications:" ndraws
   display
   display "--- Test Results ---"
   display "POF statistic (observed):" pofobs
   display "POF mean under H0 (bootstrap) approximately 1.0:" %%pofbootmean
   display "POF se under H0 (bootstrap):" %%pofbootse
   display "p-value (bootstrap):" %%pofboot
   display "=========================================="
end acKupiecBlockBoot
ac_1
If there are 0 or 1 or 2 exceedances, but not >=3, why does Wald QMLE give a p-value of exactly 0.0 ?
ac_1 wrote: ↑Thu Jan 22, 2026 2:57 am If there are 0 or 1 or 2 exceedances, but not >=3, why does Wald QMLE give a p-value of exactly 0.0 ?
For how many observations and what value of alpha?
I'm not sure what it is that you think that procedure is doing, but it's not block bootstrapping. The only thing that you are reshuffling are the independently drawn random numbers, and reshuffling independent random numbers produces independent random numbers.
ac_1
TomDoan wrote: ↑Thu Jan 22, 2026 8:04 am
staggered forecasts 1000 obs down to 991 obs, alpha = 0.01.
It doesn't work for 0 because there is nothing in the formula that forces the alphahat to [0,1] when there are no data points that apply to the log(alphahat). And even if it's tweaked to limit the alphahat, the asymptotics don't work when the parameter is on the boundary. (The same is true for the standard likelihood ratio test)
It should work fine for small positive numbers,
ac_1
TomDoan wrote: ↑Thu Jan 22, 2026 11:44 am It doesn't work for 0 because there is nothing in the formula that forces the alphahat to [0,1] when there are no data points that apply to the log(alphahat). And even if it's tweaked to limit the alphahat, the asymptotics don't work when the parameters is on the boundary. (The same is true for the standard likelihood ratio test).
ac_1
TomDoan wrote: ↑Thu Jan 22, 2026 9:08 am I'm not sure what it is that you think that procedure is doing, but it's not block bootstrapping. The only thing that you are reshuffling are the independently drawn random numbers, and reshuffling independent random numbers produces independent random numbers.
How do I fix so that it is block bootstrapping the Kupiec statistic properly, and thus is able to correctly assess multi-step ahead VaR forecasts.
You shuffle the values of the trigger series, not a randomized series.
ac_1
TomDoan wrote: ↑Thu Jan 22, 2026 2:31 pm You shuffle the values of the trigger series, not a randomized series.
Sorry, are you saying the fix is
set bootviol startl endl = trigger(bootentries(t))
Then, the p-value for Day 1 is completely different from the analytical Kupiec.
ac_1 wrote: ↑Thu Jan 22, 2026 3:21 pm
I'm not sure what you're asking. That's the whole point of bootstrapping---it generates an empirical distribution rather than the asymptotic.
ac_1
acKupiecBlockBoot.src:
S1. Counts actual violations in the VaR OOS sample.
S2. Computes Kupiec POF statistic as usual.
S3. Generates many synthetic violation series under H0 (correct VaR model): H0 : violation probability = alpha (correct unconditional coverage)
S4. Uses block bootstrap with blocklength = h to reproduce the clustering caused by overlapping h-day returns.
S5. Computes the Kupiec statistic for each synthetic series.
S6. Compares the real statistic to the bootstrap distribution.
It is a valid test for h-day VaR, unlike the standard Kupiec test.
Randomly rearranging (block bootstrapping) independent random variables as in your S4 does not produce correlated random variables.
Block bootstrapping is applied to (mildly) serially correlated actual data to try to maintain as much as possible of the correlation structure.
