Simulating data series using DLM
Martin
Unread post by Martin »
Hi, I want to simulate a data series of Y that follows a state-space model:
Y=PI*S
S=M*S{1}+G*e,
where e has a identity variance-covariance matrix. I want RATS to start from S(0) as a zero vector, and simulate a Y data series. Here is what my program is and the outcome. But my simulated Y series is full of NA. What's wrong here? Thanks for your help. Best, Martin.
disp PI
0.19936 -0.19936 0.07611 -1.90270 0.00000
0.06879 -0.06879 0.03659 -0.11475 0.00000
0.00947 -0.00947 0.00878 -0.21954 0.00000
1.14430 -0.14433 0.04684 -1.81090 1.00000
0.08000 -0.08000 0.03200 0.00000 0.00000
0.00000 0.00000 0.00000 0.80000 0.00000
1.00000 0.00000 0.00000 0.00000 1.00000
disp M
1.50000 -0.50000 0.00000 0.00000 0.00000
1.00000 0.00000 0.00000 0.00000 0.00000
0.00000 0.00000 0.80000 0.00000 0.00000
0.00000 0.00000 0.00000 0.00000 0.80000
disp G
0.00000 0.00000 1.00000 0.00000
0.00000 1.00000 0.00000 0.00000
disp vm
all 200
dlm(c=tr(PI),a=M,f=G,type=simulate,yhat=y,sw=vm)
disp y(50)
NA NA NA NA NA NA NA
There are a couple of small "workarounds" that you'll need to get this to work properly. Replace your DLM with:
dlm(c=tr(PI),a=M,type=simulate,yhat=y,y=||1.0,1.0,1.0,1.0,1.0,1.0,1.0||,sw=g*tr(g)) / xstates
The "F" option (added with version 7) doesn't work properly with TYPE=SIMULATE or TYPE=CSIMULATE (which we didn't know until you posted this). So the SW option will have to provide a full 5x5 covariance matrix. (Don't worry about this being singular). The added Y=||....|| option (the value could be any 7-vector) is needed to convince TYPE=SIMULATE that you want the complete vector.
These are both due to bugs in 7.00 which will be fixed in version 7.1.
