I have a matrix [rectangular matrix], A. I want to treat each column as a series, and transform A into a vec[ser] variable C. I encounter a problem that can be represented by the following code:
dec rec A(3,2)
comp A=||1,2|3,4|5,6||
dec vec[series] C
do i=1,2
do j=1,3
gset C(i) j j = A(j,i)
## P3. Instruction GSET Requires Parameter series
The Error Occurred At Location 0079 of loop/block
Line 2 of loop/block
Apprecitate for any comment.
