set working directory
Use this for suggestions about improvements in RATS
randerson
Unread post by randerson »
It would be nice to have a command that allows setting the working directory inside a program. execpath is almost the same except that it requires you have started the program... There exists a menu command to set working directory, so the functionality exists, but there does not seem to be a programming command for the same functionality. (I searched the reference manual in Acrobat, and did not locate such a function...)
My apology if I missed such a command.
Richard Anderson
Re: set working directory
randerson wrote:It would be nice to have a command that allows setting the working directory inside a program. execpath is almost the same except that it requires you have started the program... There exists a menu command to set working directory, so the functionality exists, but there does not seem to be a programming command for the same functionality. (I searched the reference manual in Acrobat, and did not locate such a function...)
Richard Anderson
I'm not sure why it's not documented, but (for instance)
env path=c:\rats\textbooks\greene
will do the trick. We will also be adding a "recently used directories" operation to a future release.
