simulation
iloverats
simulation
Unread post by iloverats »
dear all
how can i generate a series x,which is the granger causality of y? :?:
for example
x=a*x{1}+b*y{1}+et
:D
best
Re: simulation
iloverats wrote:dear all
for example
x=a*x{1}+b*y{1}+et
:D
best
Something like this. You need a DGP for y as well, which is here an autoregression.
all 120
set x = 0.0
set y = 0.0
frml xf x = .6*x{1}+.2*y{1}
frml yf y = .0*x{1}+.8*y{1}
group(cv=%identity(2)) twovar xf>>x yf>>y
simulate(model=twovar,from=2,to=120)
Typically, you would discard a certain number of early data points since the pre-sample zeros aren't representative of the process---this generates through 120 so that you can use 21-120 as 100 data points.
iloverats
Re: simulation
for example
x=a*x{1}+b*y{1}+et
:D
best
all 120
set x = 0.0
set y = 0.0
thank you
if i want x and y all have Garch(1,1) effect
how can i modify the code
Re: simulation
iloverats wrote:thank you
I've posted code for generating an MV-GARCH process at
http://www.estima.com/forum/viewtopic.php?f=11&t=1024
That would be the error process, so you would need to use FORECAST with the PATHS option, instead of SIMULATE, for putting together your mean model with simulated GARCH errors.
iloverats
Re: simulation
all 120
set x = 0.0
set y = 0.0
the code have no residual Contemporaneou-correlations
if i want residuals are cross Contemporaneou correlated,and the correlation coefficient is 0.8
how can i modify the code :?: :D
Re: simulation
The CV option on GROUP is the covariance matrix of the residuals. Make it what you want instead of the identity.
iloverats
Re: simulation
TomDoan wrote:The CV option on GROUP is the covariance matrix of the residuals. Make it what you want instead of the identity.
Dear
If i want y and x are all nonstationary , how can i set it?
thank you very much
Re: simulation
The covariance matrix has nothing to do with non-stationarity. You need to pick a set of lag coefficients which will do that. Write down a model in VECM form and solve it out for the original variables.
iloverats
Re: simulation
TomDoan wrote:The covariance matrix has nothing to do with non-stationarity. You need to pick a set of lag coefficients which will do that. Write down a model in VECM form and solve it out for the original variables.
Dear
May you give me an example?
thank you
Re: simulation
Engle and Granger(1987) in "Co-Integration and Error Correction", Econometrica, vol 55, no 2 give about six examples of DGP's for non-stationary VAR's.
