I would like to know how I can print the base projection values of my VAR. In other words, I am performing a historical decomposition and can get the graphs for a specific period to work but can't print the values generated by my VAR for that period. What command should I use? I appreciate any help with this,
Rafael
Print the base projection values
Re: Print the base projection values
If you look at HISTORY.RPF, the base projections are in HISTORY(1,J) as J goes from 1 to the number of variables. So you can just do a PRINT or COPY on those. For instance:rafaeldfcosta wrote:Hi Tom,
Rafael
print / history(1,1) history(1,2) history(1,3) history(1,4) history(1,5) history(1,6)
