GARCH(1,1) using Max instruction
sulong
Unread post by sulong »
Tom,
What is wrong with my instructions ( please see below )?
The output i get is different from the output generated from the GRACH instruction.
I am trying to use the MAX instruction for a GARCH(1,1) process.
Many thanks,
sulong
OPEN DATA "/Applications/RATS 8.0/Examples/garch.asc"
DATA(FORMAT=PRN,NOLABELS,ORG=COLUMNS) 1 1867 BP CD DM JY SF
table
set dlogdm = 100*log(dm/dm{1})
set temp = 0.0
nonlin a0 b0 b1 b2
frml ep = dlogdm - a0
frml h = b0 +  b1*(ep{1}**2) +  b2*temp{1}
frml L = (temp=h), -0.5*log(h) - ep**2/h
com a0=1, b0=1, b1=1, b2=1
max L 4 *
GARCH(P=1,Q=1) / DLOGDM
Re: GARCH(1,1) using Max instruction
You have differences in the sample range (your MAX code starts at 4, GARCH at 2) and your pre-sample values. The following will produce exactly the calculations done by GARCH (though I wouldn't recommend b1=1 and b2=1 as guess values; that gives an explosive variance process).
table
linreg dlogdm
# constant
set uu   = %sigmasq
set temp = %sigmasq
nonlin a0 b0 b1 b2
frml h = b0 +  b1*uu{1} +  b2*temp{1}
frml L = (temp=h),uu=ep^2, %logdensity(h,ep)
max L 2 *
