King, Plosser, Stock, Watson (AER 1991)
These are replication files for King, Plosser, Stock and Watson(1991), "Stochastic Trends and Economic Fluctuations", AER, vol 81, pp 819-840. This does extensive analysis of the properties of the cointegration space on three and six variable systems, and includes examples of many important RATS procedures, such as @JOHMLE, @SWDOLS and @FORCEDFACTOR, and ESTIMATE with an error correction term.
Zip with all programs and data files
kpsw1.rpf
(2.6 KiB) Downloaded 1184 times
Unit root tests, analysis of roots of VAR, preliminary analysis of cointegration using the @SWTRENDS, @SWDOLS and @JOHMLE procedures.
kpsw2.rpf
(975 Bytes) Downloaded 1286 times
Tests of restrictions on the cointegrating vectors. Uses SWDOLS extensively.
kpsw3.rpf
(1.31 KiB) Downloaded 1121 times
More tests of restrictions on the cointegrating vectors.
kpsw4.rpf
(3.98 KiB) Downloaded 1104 times
Monte Carlo integration of impulse responses on VECM with known cointegrating vectors.
kpsw5.rpf
(3.33 KiB) Downloaded 1123 times
VECM with estimated cointegration vectors.
kpsw6.rpf
(3.3 KiB) Downloaded 1215 times
Isolation of long-run balanced growth shock using FORCEDFACTOR.
Data file:
kpswdata.rat
(14.75 KiB) Downloaded 1301 times
Last bumped by TomDoan on Thu Mar 29, 2018 4:25 pm.
