change the vector to series
iloverats
Unread post by iloverats »
dear
how can i change the vector to series
for example
dec vect xx(100)
thank you :D
Re: change the vector to series
If you look under MAKE in the Reference Manual, it gives several options for "unmaking" a matrix into one or more series.
