Papell-Prodan(2006) Unit Root Tests with Breaks
This is a replication for the unrestricted break models from Papell and Prodan(2006), "Additional Evidence of Long Run Purchasing Power Parity with Restricted Structural Change", Journal of Money, Credit and Banking, vol. 38, no 5, 1329-1349. This uses the @PerronBreaks procedure with one and two breaks. (@PerronBreaks was updated in September 2011).
The QPPP models are unit root tests with non-trending deterministics and additive mean shifts (AO=MEAN option), while the TQPPP models use trending deterministics with additive mean shifts (AO=CRASH option).
pp2006.rpf
Program file
(3.57 KiB) Downloaded 1448 times
alan taylor data.wf1
Data file
(25.54 KiB) Downloaded 1321 times
Tony
Re: Papell-Prodan(2006) Unit Root Tests with Breaks
Unread post by Tony »
When I run the pp2006 code,I got the following:
## SX11. Identifier %%SHIFTS is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>(%minent) %%shifts(<<<<
for your information, I am using RATS 8.0. May I know Why this output? Tks.
You need to get the updated PERRONBREAKS procedure off the link in the original post.
