Series name
Barry Quinn
Series name
Unread post by Barry Quinn »
I am new to RATS so excuse the simplicity of this question!
I am running a procedure which produces a number of wald statistic series.
It names these Series WSTAT(1), WSTAT(2) etc.
After estimation RATS doesn't recognise these names in subsequent commands such as GRAPH, SET.
e.g
graph
# wstat(1)
## SX11. Identifier WSTAT is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>># wstat(<<<<
Is there something obvious i am missing.
thanks
Re: Series name
Those are presumably declared as local vect[series] in the procedure. If you change the "local" to "declare", you'll be able to use these outside the procedure.
Barry Quinn
Re: Series name
Many thanks can no use these variables
