REGTOTEX—Formatting regression equations
The attached procedure takes the most recent regression and generates a TeX equation to display it in the standard form with coefficients x variables in the first line with standard errors in parentheses under the coefficients.
regtotex.src
Detailed description
This PDF file demonstrates the use of the procedure with an example. The example and data file for it are also provided.
RegToTex.pdf
Description
(37.59 KiB) Downloaded 828 times
regtotex_example.rpf
Example program
(507 Bytes) Downloaded 1108 times
hprice2.raw
Data file for example
(66.21 KiB) Downloaded 1134 times
Last bumped by TomDoan on Tue Jun 16, 2015 7:21 pm.
