rolling out of sample forecasts (ARMA+GARCH)
potiv
Unread post by potiv »
I wonder if I could ask for your kind help to double check whether the code below is ok. I need to forecast the rolling out of sample mean and variance of a number of series and its really crucial that I get the 'time subscripts' right. The model is a relatively simple ARMA+GARCH. My big worry is that I might inadvertently put, say, the predicted variance for period t+1 into period t, or something like that. Many thanks in advance for your help (as well as for all the help offered in the past!). :) :D
Best regards,
Valerio
**************   dep is the dependent variable ********************
source bjautofit2.src
source garchfore.src
dec vec[series] means(nr) vars(nr) sr(nr)
com window = 60
infobox(action=define,progress,lower=1,upper=nr)
do i=1,nr
  clear dep mean var
  set dep = y(i)
  inquire(series=dep) start end
  do time = start+window,end-1
 	@bjautofit2(diffs=0,noprint,constant,pmax=5,qmax=5,crit=aic) dep time-window time
   	com ar = %%autop, ma = %%autoq
     equation armagarch dep ar ma
   	garch(p=1,q=1,print,model=armagarch,hseries=ht,resids=at,PMETHOD=SIMPLEX,PITERS=20) time-window+fix(%max(ar,ma)) time dep
     if %converged==1
      @garchfore(steps=1) ht at
      uforecast(equation=armagarch,steps=1) m
      com mean(time+1) = m(time+1)
      com var(time+1) = ht(time+1)
     else
     com mean(time+1) = %na
     com var(time+1) = %na
  end do time
  set means(i) start+window end = mean
  set vars(i) start+window end = var
  set sr(i) start+window end = means(i)/sqrt(vars(i))
  infobox(current=i)
dis 'Portfolio nr: ' i
infobox(action=remove)
Re: rolling out of sample forecasts (ARMA+GARCH)
That looks correct.
potiv
many thanks! :D
Valerio
