* @CANCORR( options ) start end
* # list of "Y" variables (regression format)
* # list of "X" variables (regression format)
* # list of conditioning variables (regression format, if CONDITION option)
* Computes the canonical correlations and related statistics for two sets of
* series, possibly conditioning on the third set.
* Parameters:
* start end range to use. By default, the maximum range allowed by the
* variables involved.
* Options:
* CENTER/NOCENTER If CENTER, the means are subtracted from the variables before
* computing the covariance matrix. The default is CENTER unless you use the
* CONDITION option.
* CONDITION/[NOCONDITION] If CONDITION, the covariance matrix analyzed is that of
* the residuals from a regression on the conditioning set of variables. This
* will generally include the CONSTANT (so residuals will be mean zero) in
* addition to the other variables.
* EIGENVALUES=(output) VECTOR of eigenvalues, ordered from high to low. These will
* all be >=0 and <=1.
* VECTORS=(output) RECTANGULAR of eigenvectors for the X variables. Column <<i>> has
* the weights for canonical component <<i>> of the X's.
* DUALVECTORS=(output) RECTANGULAR of eigenvectors for the Y variables. Column <<i>>
* has the weights for canonical component <<i>> of the Y's.
* LOADINGS=(output) RECTANGULAR of coefficients on a multivariate regression of the
* Y's on the canonical components of the X's. Element (i,j) has the coefficient
* for component j of the X's in the regression for Y.
* Revision Schedule:
* 03/2008 Written by Tom Doan, Estima.
procedure cancorr start end
type integer start end
option switch center 1
option switch condition 0
option rect *vectors
option rect *dualvectors
option vect *eigenvalues
option rect *loadings
local equation xtemp
local equation ytemp
local equation ztemp
local equation combined
local rect eigvec dualvec
local vect eigval
local rect s s01
local symm s00 s11
local symm s10_00_01 s01_11_10
local int nx ny nz
* Get the two main sets of variables
equation ytemp *
equation xtemp *
compute ny=%eqnsize(ytemp)
compute nx=%eqnsize(xtemp)
* Combine them into a single list for computing the cross product matrix.
compute combined=ytemp+xtemp
* If <<condition>>, get the third set of variables, and append it to the combined
* list.
if condition {
equation ztemp *
compute combined=combined+ztemp
compute nz=%eqnsize(ztemp)
* Compute the grand crossproduct matrix and divide through by the number of
* observations to get the raw covariance matrix.
cmom(center=center.and..not.condition,equation=combined) start end
compute s=%cmom*(1.0/%nobs)
* If <<condition>>, sweep out the conditioning set of variables
if condition
compute s=%sweeplist(s,%seq(nx+ny+1,%ncmom))
* Pull out the required submatrices from the block of the y and x variables.
compute s00=%xsubmat(s, 1,ny , 1,ny)
compute s11=%xsubmat(s,ny+1,ny+nx,ny+1,ny+nx)
compute s01=%xsubmat(s, 1,ny ,ny+1,ny+nx)
* Compute the generalized eigenvalues and vectors. The first calculation gets the
* canonical components for the "X" variables.
compute s10_00_01=tr(s01)*inv(s00)*s01
eigen(general=s11) s10_00_01 eigval eigvec
* Save the parts that the user wants
if %defined(eigenvalues)
compute eigenvalues=eigval
if %defined(vectors)
compute vectors=eigvec
if %defined(loadings)
compute loadings=s01*eigvec
* If we want the dual vectors as well, compute the reverse problem and save the
* eigenvectors.
if %defined(dualvectors) {
compute s01_11_10=s01*inv(s11)*tr(s01)
eigen(general=s00) s01_11_10 eigval dualvec
compute dualvectors=dualvec
