%binomial and fix
MMandler
%binomial and fix
Unread post by MMandler »
I want to construct a n-vector containing the integer binomial coefficients (n,i) where i is the row of the vector. I found that transforming the real binomial coefficients into integers by using the FIX command leads to changes in the coefficient's values.
Here is an example code. The problem seems to occur only for n<=5.
declare integer n
compute n=5
declare vector[integer] bincoeff(n)
do i=1,n
compute bincoeff(i)=fix(%binomial(n,i))
display %binomial(n,i) fix(%binomial(n,i))
Martin
Re: %binomial and fix
Use %round(...,0). %fix(x) gives the largest integer less than x, so if the calculation of the binomial coefficient (which is done using gammas and thus isn't exact except for small values) comes in just below the true integer, you get 4 rather than 5. %round(...,0) gives the closest integer.
do i=1,n
compute bincoeff(i)=%round(%binomial(n,i),0)
display %binomial(n,i) %round(%binomial(n,i),0)
MMandler
Thanks for the hint.
Martin
