Combining Responses in The Same Graph
nazif
Unread post by nazif »
Dear,
I have written the following code to compare the responses to variables in the same VAR model focusing on different samples. Could you please show me how to combine responses in the same graph with the same vertical scale?
open data oil_output_rats_level_en_eco.xls
calendar(m) 1987
data(format=xls,org=columns) 1987:1 2011:3
compute [vect[strings]] implabel=|| "dlind","dlcoil", "dlner", "dlgasr", "dlcpi"||
compute  nsteps = 18
compute  p = 3
set low =  DLCPI{1}< 0.01746
set high = DLCPI{1}>=0.01746
graph(shading=high) 1
# DLCPI
*******Linear VAR******************************************************************************
system(model=poilmodel2)
variables DLINDTR DLROIL DLNER DLgaSCPI DLcPI
lags 1 to p
estimate(resids=varresids)
errors(model=poilmodel2,window="Variance Decomposition(linear)", steps=nsteps)
impulse(model=poilmodel2, window="Impulse Responses", steps=nsteps, result=impulses)
@MCVARDoDraws(model=poilmodel2, steps=nsteps)
@MCGraphIRF(model=poilmodel2,VARLABELS=implabel,SHOCKLABELS=implabel,$
center=mean,page=byshock,HEADER='Linear VAR',STDDEV=1.0 )
*********High Inflation Regime********************************************************
system(model=poilmodel1)
lags 1 to p
estimate(resids=varresids, smpl=high)
errors(model=poilmodel1,window="Variance Decomposition(High)", steps=nsteps)
impulse(model=poilmodel1, window="Impulse Responses", steps=nsteps, result=impulseshigh)
@MCVARDoDraws(model=poilmodel1, steps=nsteps)
@MCGraphIRF(model=poilmodel1,VARLABELS=implabel,SHOCKLABELS=implabel,$
center=mean,page=byshock,HEADER='High Inflation',STDDEV=1.0)
******Low inflation Regime************************************************
system(model=poilmodel3)
lags 1 to 4
estimate(resids=varresids, smpl=low, noprint)
errors(model=poilmodel3,window="Variance Decomposition(Low)", steps=nsteps)
impulse(model=poilmodel3,window="Impulse Responses", steps=nsteps, result=impulseslow)
@MCVARDoDraws(model=poilmodel3, steps=nsteps)
@MCGraphIRF(model=poilmodel3,VARLABELS=implabel,SHOCKLABELS=implabel,$
center=mean,page=byshock,HEADER='Low Inflation',STDDEV=1.0)
Re: Combining Responses in The Same Graph
The Ehrmann, Ellison, Valla replication includes a way to interleave regime-specific responses into a single graph:
http://www.estima.com/forum/viewtopic.php?f=8&t=1192
nazif
Dear Doan,
Thanks. But I need to recover responses with their error bands using monte carlo simulations with mcdodraws procedure and then make them side-by-side graphs with the same scale on the vertical axis so that I can make proper comparisons. In the attached document I plotted responses to output using byshock option mcgraphirf. As I understand the vertical limit is determined by the maximum and minimum values of error bands. How can I assign specific values for the vertical min and max in this procedure?
Nazif
responses.docx
responses_to_output
(37.43 KiB) Downloaded 856 times
nazif
Dear Doan,
Sorry about taking your time I will use MCProcessIRF procedure and then combine individual responses with spgraph.
Nazif
