Example of VECM with BQ restrictions and Error Bands
macro_man
Unread post by macro_man »
All,
Are there any examples of a VECM that uses Blanchard-Quah long-run restrictions and calculates error bands for the impulse response functions? Thanks.
Re: Example of VECM with BQ restrictions and Error Bands
KPSW4.RPF (from King, Plosser, Stock and Watson AER 1991) does Monte Carlo integration on a VECM with long-run restrictions. BQ itself isn't that interesting since if you have a two-variable VECM, if one variable has a long-run 0 restriction, the other has to as well.
macro_man
Thanks. Can you direct me to a resource that explains why this is so. My models have 6-8 variables, but the issue I assume still applies.
macro_man
Tom,
I followed the ShortandLong example with VECM. Is there an example for the shortandlong where standard error bands are generated? Thanks.
carljames
Unread post by carljames »
I was actually having a hard time to determine the who permanete shock originates from, but it seems that you can't, huh?! :(
Honestly, it's a little confusing
"For a gallant spirit there can never be defeat."
Team Slim Max
carljames wrote:I was actually having a hard time to determine the who permanete shock originates from, but it seems that you can't, huh?! :(
That's correct. The BQ restriction actually identifies the transitory shock---the permanent shock is whatever is orthogonal to that. You would need a more structural model than a simple VECM to identify the source of the permanent shock.
