Complex matrix to real matrix
g_defi
I am seeking the most convenient way to transform a complex matrix into a real matrix in a formula (frml)?
Can I use something like ewise instruction?
Best regards.
Best regards.
Re: Complex matrix to real matrix
I'm not sure what you mean by "in a FRML". If you mean with something like an EWISE, yes:
dec rect r(n,n)
ewise r(i,j)=%real(c(i,j))
dec rect r(n,n)
g_defi
Apologize if I was not clear.
I call the %logdensitycv function in a multivariate case. Since my estimator operates in frequency domain, I try to transform my transfer function (that is a complex matrix) into a real matrix:
where "transfer" and "periodogram" are symmetric complex matrix that I want to turn into real matrix.
frml logl = %logdensitycv(transfer,periodogram,(float(n)/m))-
The complex matrix equivalent of %LOGDENSITYCV would require arguments which are the spectral density implied by the model, the periodogram and the number of observations. The transfer function in this case would be a SERIES[CVECTOR] instead, and you would use that combined with the model spectral density in a complex equivalent of %LOGDENSITY. Which of the two do you have?
The attached function computes the log density of a complex Normal.
- cxlogdensity.src
- Procedure/function file
- (751 Bytes) Downloaded 1118 times
g_defi
Thanks for your reply.
Unfortunately I think I cannot use the complex log density of Normal because I perform a Whittle approximation of the Maximum Likelihood.
My problem is like trying to modify the FRACTINT.RPF file in order to estimate a bivariate VARFIMA(1,d,0).
This extends %LOGDENSITYCV to complex matrices. That looks like what you want.
g_defi
Yes it is. Thank you very much for your help!
Best regards.
Best regards.
