Cai SWARCH model
PeterF
Cai SWARCH model
Unread post by PeterF »
I try to replicate the Cai model of Markov switching ARCH. The SWARCH.rpf is based on this model. It was not a problem to change it to the two state model. However, in the Cai model, the formula is not just u(t)=(y-mu), but u depends on the state variable as well as on lagged values of u. Thus, the FRML statement (at the end of UG-369) has to be modified. But at this point I am lost somewhat. I changed the FRML statement to
frml logl = u(t)=(x-c0-c1*%if(pstar(1)<0.5,1,0)-b1*temp{1}), temp=u(t),uu(t)=u(t)^2,f=ARCHStateF(t,u(t)),$
pt_t1=%mcstate(p,pstar),pt_t=pstar=%msupdate(f,pt_t1,fpt),log(fpt)
I have defined and initialized the parameters, c0,c1 and b1 and set the temp series to 0.0 before the frml statement is executed. Running the modified SWARCH program leads to the no conversion statement. Is it logical mistake that I made or is it just the data which leads to no result for the maximization?
Best regards
Peter
Re: Cai SWARCH model
The Dueker SWARCH/SWGARCH models also include a switching mean: http://www.estima.com/forum/viewtopic.php?f=8&t=1190. His SWARCH uses the Hamilton-Susmel form rather than Cai, but the handling of the switching mean model would be the same either way.
PeterF
Tom,
thanks a lot for the very quick help
