VAR's under Regime Shifts
blucey
Unread post by blucey »
Anybody got code for regime shifting VAR/VECM?
zoo
Unread post by zoo »
for a linear shift if you use cats in rats you can adding two lines such as:
set D85 78:6 85:03 = 0
set D85 85:03 96:06 = 1
where the dummy D85 lies in the cointegration space.
blucey
zoo wrote:for a linear shift if you use cats in rats you can adding two lines such as:
Indeed. However, I should really try to make myself clear when I post.... I meant in essence Markov Shifting VAR's
