Tse, JOE 2000 test for CC
This demonstrates the Tse LM test for constant correlation, replicating the results results in Tse, Y. K.(2000), "A Test for Constant Correlations in a Multivariate GARCH Model", Journal of Econometrics 98, 107-127. This starts with an estimate of a CC model and does an LM test for whether the covariances seem to also depend upon lagged outer products of the residuals.
This uses the @TSECCTEST procedure. Note that the GARCH model cannot use off-diagonal covariances in either the mean or variance models. The use of variances is OK, so you can have an "M" model which uses variances, but not the covariances.
tse.rpf
Program file
(1.18 KiB) Downloaded 1066 times
exratew.dat
Data file
(19.03 KiB) Downloaded 1144 times
abi
Re: Tse, JOE 2000 test for CC
Unread post by abi »
What is null in Tse test?
CC.
abi
TomDoan wrote:CC.
Thank's Tom,
If the null is rejected then it means i should use DCC rather than CC or only i can not use CC?
No. It only means that CC doesn't seem to be adequate. Whether any specific alternative is better isn't clear.
