Spgraph Codes
guo
Spgraph Codes
Unread post by guo »
Always thank you very much for your kind help.
I'd like to put four graphs together by using Spgraph.
Here are the codes:
set tvalues_i = tvalues_1,tvalues_4
set fvalues_i = fvalues_1,fvalues_4
spgraph(vfields=2,hfields=2,$
header="IM_CO, IM_CO_61, IM_CO_62 and IM_63",$
subtitle="The Relationship Between Theta and Inflation")
 do i = 1 , 4
  scatter
  # tvalues_i fvalues_i
  end do
Actually, the four graphs should be different. However, the four graphs in the same sheet are same.
Could you please tell me why this codes are wrong?
I am very looking forward to your kind answer.
Thank you very much.
Best Regards
guo
Re: Spgraph Codes
tvalues_i is not the way to reference the ith element in a sequence. If you've already defined tvalues_1,...,tvalues_4 and the same for fvalues_?, then you want
scatter
# %s("tvalues_"+i) %s("fvalues_"+i)
If you haven't defined them, then you should probably be defining TVALUES and FVALUES as VECT[SERIES], that is
dec vect[series] tvalues(4) fvalues(4)
do i=1,4
set tvalues(i) = ....
set fvalues(i) = ....
scatter
# tvalues(i) fvalues(i)
istiak
Spgraph code
Unread post by istiak »
Hi Tom
I am using spgraph option to create two graphs together. The codes are below.
spgraph(vfields=2)
graph(vlabel="Consumption",hlabel="time")
# c
graph(hlabel="Capital",hlabel="time")
# k
The code creates both consumption and capital graph in two rectangular boxes. If I need to get the graphs only with horizontal & vertical axis (I don't want north and east border of the box), how should I modify the above code? Thank you so much.
Re: Spgraph code
istiak wrote:Hi Tom
spgraph(vfields=2)
# c
# k
Use the ROW and COL options on GRAPH:
spgraph(vfields=2)
graph(vlabel="Consumption",hlabel="time",row=1,col=1)
# c
graph(hlabel="Capital",hlabel="time",row=2,col=2)
# k
istiak
Re: Spgraph Codes
Hi Tom
I am sorry, I could not make my problem clear to you. I am attaching a graph. By default, rats creates graphs in a box (same as lower panel in my picture). But I want to get graphs like the upper panel, where only X and Y axis are present. Is there any code to do it? Thank you Tom.
Doc1.pdf
(102.7 KiB) Downloaded 1001 times
Re: Spgraph Codes
Sorry. What you want has nothing to do with SPGRAPH.
Each of the main graphics instructions (GRAPH, SCATTER, GCONTOUR, GBOX) has a FRAME option. The default is FRAME=FULL, which draws all four sides. You want FRAME=HALF, which does the left and lower only.
