Initial value for mvgarch model
yli725
Unread post by yli725 »
I have some Convergence problem when I estimate a multivariate GARCH model, so I want to specify the initial value. I saw there is a method option "evaluate", but I do not know how to use that with initial.
First, I estimate a model use the code
garch(p=1,q=1,model=var4,asymmetirc,distrib=t,mv=bekk,method=bhhh,iters=500,pmethod=simplex,piters=50,hmatrices=hh,rvectors=rd) / y1 y2 y3
Then ???
garch(p=1,q=1,model=var4,asymmetirc,distrib=t,mv=bekk,method=evaluate,initial=??? iters=500,pmethod=simplex,piters=50,hmatrices=hh,rvectors=rd) / y1 y2 y3
I am a new user of Rats, thank you for your kindly help!
Re: Initial value for mvgarch model
yli725 wrote:Dear Tom,
Then ???
Changing the guess values is rarely a help. I would suggest reducing the number of simplex iterations (10-15 is usually enough) and switching from BHHH to BFGS.
