a question on business cycle synchronization
hardmann
Unread post by hardmann »
Dear Tom:
I study business cycle synchornization between countries. I simply modify the code of Stock and Watson(1991), "A Probability Model of the Coincident Economic Indicators," for two countries.
I get gamma(1)=2.5>1, is it right? I exchange the order of tow series, gamma(1) is still more than 2.
first : i_cn i_xj
open data gdp_cn_xj.txt
calendar(q) 1997
data(format=free,org=columns) 1997:1 2012:4 gdp_cn gdp_xj
set i_cn   = 100.0*log(gdp_cn/gdp_cn{1})
set i_xj   = 100.0*log(gdp_xj/gdp_xj{1})
* Parameters for index
dec vect phi(2)
compute phi=%zeros(2,1)
dec real sigmac
compute sigmac=1.0
* Parameters for the series. sigma is initialized based upon the sample
* means.
dec vect beta(2) gamma(2)
dec vect sigma(2)
dec vect[vect] d(2)
ewise d(i)=%zeros(2,1)
compute gamma=%const(1.0)
stats(noprint) i_cn
compute beta(1)=%mean,sigma(1)=%variance*.5
stats(noprint) i_xj
compute beta(2)=%mean,sigma(2)=%variance*.5
* Construct fixed parts of the A matrix
dec rect a(6,6)
compute ar2=||0.0,0.0|1.0,0.0||
compute a=ar2~\ar2~\ar2
* Construct the F matrix (always fixed)
dec rect f(6,3)
compute f2=||1.0|0.0||
compute f=f2~\f2~\f2
* Construct the fixed parts of the C matrix
dec rect c(6,2)
compute c=%zeros(2,2)~~(f2~\f2)
dec symm sw(3,3)
function %%DLMSetup
compute %psubmat(a,1,1,tr(phi))
do i=1,2
   compute %psubmat(a,2*i+1,2*i+1,tr(d(i)))
compute %psubmat(c,1,1,tr(gamma))
compute sw=%diag(sigmac~~sigma)
end %%DLMSetup
dec frml[vect] yf
frml yf = ||i_cn-beta(1),i_xj-beta(2) ||
* Estimate the parameters by maximum likelihood.
nonlin gamma d sigma phi
dlm(start=%%DLMSetup(),y=yf,sw=sw,c=c,a=a,f=f,$
   presample=ergodic,type=filter,$
   pmeth=simplex,piters=200,method=bfgs) 1997:2 * xstates
* As this is constructed, it somewhat arbitrarily fixes the pre-sample
* value of the indicator at zero.
set indicator_f 1997:2 * = xstates(t)(1)
acc indicator_f
graph(footer="Coincident Indicator, Filtered Version")
# indicator_f
dlm(start=%%DLMSetup(),y=yf,sw=sw,c=c,a=a,f=f,presample=ergodic,$
   type=smooth,print,title="smooth") 1997:2 * xstates
set indicator_m 1997:2 * = xstates(t)(1)
acc indicator_m
graph(footer="Coincident Indicator, Smoothed Version")
# indicator_m
second : i_xj i_cn
calendar(q) 1997
dec vect phi(2)
dec real sigmac
compute sigmac=1.0
* means.
dec vect sigma(2)
dec vect[vect] d(2)
stats(noprint) i_cn
stats(noprint) i_xj
dec rect a(6,6)
dec rect f(6,3)
dec rect c(6,2)
dec symm sw(3,3)
function %%DLMSetup
do i=1,2
end %%DLMSetup
dec frml[vect] yf
frml yf = ||i_xj-beta(1),i_cn-beta(2) ||
   pmeth=simplex,piters=10,method=bfgs) 1997:2 * xstates
acc indicator_f
# indicator_f
   type=smooth) 1997:2 * xstates
acc indicator_m
# indicator_m
gdp_cn_xj.txt
data file
(1.55 KiB) Downloaded 861 times
Re: a question on business cycle synchornization
hardmann wrote:Dear Tom:
Why would you think there's a problem? GAMMA's are loadings from the cycles onto the series. Since (for normalization) the variance of the shock to the cycle is standardized to one, the scale of gamma can be anything depending upon the values of your dependent variables.
hardmann
Dear Tom:
Thanks. I am still confused. We estimate first model with order i_cn, i_xj,gamma(1) of i_cn=2.5>1, gamma(2) of i_xj<1, while second model with order i_xj, i_cn, gamma(1) of i_xj =2.7>1, gamma(2) of i_cn<1, which is right?
Best regard
Hardmann
Probably neither. This isn't a model which is likely to handle well two series which, at least from graphical inspection don't seem to have any strong common cycle. You have an AR(2) on the unobserved cycle, plus AR(2) noise processes for each series. That's quite a bit of action for two series. If they were more closely linked, it might work, but probably not with the two that you have.
