Lee-Strazicich (LM) Unit Root Test
Hello sir, I need your help for understanding the output result of Lee and Strazicich unit root test. I am getting my test results in the below given format. basically, I not able to understand which is LM coefficient in the output table below and then how to calculate lembdas from this result. I will be greatful to you for your help and cooperation.
Lee-Strazicich Unit Root Test, Series SDP
Regression Run From 1986:01 to 2004:01
Observations 13
Crash Model with 2 breaks
With 0 chosen from 5
Variable Coefficient T-Stat
S{1} -0.6210 -1.8787
Constant -17.6988 -0.8250
D(1989:01) -23.9401 -3.0851
D(1997:01) 61.9471 7.2655
Observations 13
Trend Break Model with 2 breaks
With 5 chosen from 5
S{1} -2.7279 -14.2298
Constant 9.1735 5.5809
D(1989:01) -133.4288 -0.0000
DT(1989:01) 134.5588 0.0000
D(1990:01) 9.2571 2.2997
DT(1990:01) -157.3393 -0.0000
Observations 13
Observations 13
Prakash Singh
Senior research Analyst
Institute of Economic Growth
New Delhi, India
New Delhi, India
Re: Lee-Strazicich (LM) Unit Root Test
The test statistic is the T-Stat on S{1}, in this case the -1.8787.prakash wrote:Hello sir, I need your help for understanding the output result of Lee and Strazicich unit root test. I am getting my test results in the below given format. basically, I not able to understand which is LM coefficient in the output table below and then how to calculate lembdas from this result. I will be greatful to you for your help and cooperation.
Lee-Strazicich Unit Root Test, Series SDP Regression Run From 1986:01 to 2004:01 Observations 13 Crash Model with 2 breaks With 0 chosen from 5 Variable Coefficient T-Stat S{1} -0.6210 -1.8787 Constant -17.6988 -0.8250 D(1989:01) -23.9401 -3.0851 D(1997:01) 61.9471 7.2655
Dear Tom, Thanks for your help, I have one more query in this regard and that is in my result whether the the t- statistics which I have got are LM(tuo) or LM (rho). if you could put some light on it I will be thakful to you
Prakash Singh
New Delhi, India
New Delhi, India
